1 - 2 of 2 Posts
Hi yall this is my first time posting as I have a 99 honda odyssey. the odometer reads 225k with a tranny replaced at 200k. car runs smooth but these lights on the instrument cluster bothers me and would like some input. FIRST off the TCS sensor light is on , The SRS light is On and the BRAKE light is On and the dreaded CHECK ENGINE light is ON. i took it to the dealer to have it diagnosed and they came back saying it was a cat converter and EGR valve that it would cost over a grand to fix. i replaced both parts with new parts for cheaper than dealer price but the lights are still on. anybody having the same problems?????? any insights , inputs , solutions will help..thanks in advance
What were the codes?
The EGR has a Tech Service Bulletin. Replacing the valve is not enough. Port reaming and cleaning needed.
The BRAKE light means you need to check the brake fluid level, the switch or you have a burnt out rear left or right brake light bulb.
1 - 2 of 2 Posts
