1 - 7 of 7 Posts
Our van has a weird problem. The front side passenger door can't be locked. It seems that something is jammed. Power lock/unlock doesn't work. When I try to push down the locking tab, it feels that something is blocking it and I can't push it down. I removed the door panel, but the lock assembly couldn't be accessed just by doing that.
This just happened yesterday and I wonder what's wrong with it. Is it the actuator or a bad lock assembly? Please help!
Thanks!
Thanks for your suggestion! If it were the lock actuator, I'd think that it should only affect the power lock. The manual tab should still work. In my case, I can't even push the tab down. I tried to find out how the lock mechanism works, but couldn't find any material that explains it clearly.
Some reference material to get you started. I personally was able to disassemble the panel and remove the actuator but I had to cave in and let the dealer install the new one.
Thanks for the information provided and the document written by andyf80! The problem was in fact the actuator. It's apparently stuck, and was blocking the locking mechanism. I removed it for now, and will be replacing it once my order arrives.
Thanks again!
Let me know how the install of the actuator was as I was not able to do it. I think I was supposed to remove the outside door handle for easier access.
1 - 7 of 7 Posts
