Hello everyone, the battery of my 2000 Ody EX was dead today but after jumped it, the van started right up. I drove to the AutoZone to test the battery and the alternator. Here are the result per tested with the rep.
1 = Alternator indicates to be 59amp, instead of 130amp for new alternator for this van.
2 = The tester indicates BAD BATTERY.
The rep. recommended me to replace the alternator and maybe I don't need new battery.
Please give me your advice. I couldn't find DIY to replace just the alternator - please walk me thru the process would be great.
Thanks in advance for your help.
mjody said:
I would try a new battery and then re-test the alternator. The alt reading is not accurate if the battery is faulty.
This maybe the least expensive option and I still be able to return the battery if it is the alternator issue right?
Are you sure that Autozone did the test properly? I wouldn't put too much stock into their result.
I would get a new battery and go from there. Batteries live short lives in these vans, especially when they do a lot of short-trip duty.
After the test yesterday, I started the van twice between 3-4 hours sitting in really cold Minnesota Winter and let her warm up around 15min each then this morning she started right up.
That's 2 votes for new battery so I will try this option first and see. Thanks again guys!
