1 - 2 of 2 Posts
Hello all! Again.... it's the door problem. My situtation is kinda different than other. I tried the fuse method, but it didn't work. I can't even get the door open manually.
Now the driver side sliding door just stuck closed. won't open regardless if you use the button or your hand.
I guess something is broken inside the door.
My question is:
1. Can I take the panel off with out opening the door?
2. Is there any tips for this kinda situation?
Thank you for looking and helping!
Discussion Starter #2
alright. I took the panel off(easy). and found the problem. looks like it'a some cable jaming and the plastic parts are getting old in there. I might just pick up the whole system from a junk yard and replace everything "in" the door.
1 - 2 of 2 Posts
