1 - 2 of 2 Posts
Has anyone upgraded to poly sway bar bushings on 2nd gen ody? My wife took the van in and they say it needs struts and springs, thats fine, but as long as I am doing those, I will replace the bushings and was looking around and did not see the energy suspension poly bushings for our gen, only the previous and was not sure that they are the same, or if someone knew the custom size that would fit. Thank you all in advance!
Depends on what bushings you want to replace. The sway bar is 22mm so you can get those pretty easily, just need to measure the mount. Don't know about the endlinks or the shock bushings. Probably would have to get under the vehicle and start measuring things.
1 - 2 of 2 Posts
