1 - 1 of 1 Posts
First of all, i apologize for another sliding door tread.
But after a week of search i have not found an answer.
I have already did the fuse #13 trick, checked all fused and have the panel off and has applied power to the motor itself; which does move the motor and door back and fourth. So motor and cables are working normally.
But i get no power from dash switch, inside and outside door handle with and without childlock engaged.
I bought the van used and came with driver doornot working. The simply said it just stoped working one day.
I would like some info/pics on where i can check if they are getting good grounds.
also would like info on how to check all the switches on these.
And any other thoughts/input on how to fix this issue
Thx
1 - 1 of 1 Posts
