I imagine that your door is not closed all the way. There is a motor that pulls your door closed after the other motor slides it shut. try spraying white lithium grease into the door catch and it may help. to properly fix it, I had to take the motor out, and clean all parts with wd 40, then lube them with white lithium. It is not as hard as it may sound, I can give you directions if you want.
