I have a 2001 Ody EX with 162K miles. I was inspecting the steering and suspension before I replace the front struts. There's some play in the left front, and I can't quite pin down its source.
When I push back and forth on the sides of the brake rotor, there's some discernable play in each direction. My first thought was the steering tie-rod end / ball joint, but there's no visible play there. There's no visible play in the lower control arm ball joint.
Next I suspected wheel bearing play, but I don't get the same play from top to bottom that I get from side to side. It seems to me that if it were the wheel bearing, the play would be in all directions.
I think it's possibly the "universal" joint at the steering gear end of the tie rod.
Has anyone run into anything like this? Thoughts?
