1 - 2 of 2 Posts
I have a 2001 Odyssey although the vin is for 2002. Problem is the alarm going off when we lock the car. We found if we turned off the power door opener, the alarm did not go off randomly. Now, even with the power door turned off and the doors unlocked, the alarm goes off randomly. Has anyone else had this problem, if so, how did you solve it?
Are you sure it is going off with the doors unlocked? Anyway with the alarm armed it can be set off randomly with a flaky door closed switch. Most common causing the problem is the hood switch. Try bumping around the switches with your fist see if the vibration will set it off.
1 - 2 of 2 Posts
