The bolt pattern appears to be the same for 2005-2010 and 2011. However, 2005-2010 had used 16" rims also, I believe. The smaller diameter may or may not work with 2011 brakes. But, this should be the only reason it wouldn't work. So, if there is enough diameter space to clear the brake caliper, brake lines, etc. then it should be fine, but I don't know if this is the case. A 17" 2005-2010 rim, if it exists, would likely work. Also brought up earlier, is you have to account for TPMS sensors somehow.
