No video to offer, but you might follow a timing belt replacement procedure until the lower cover is off. The crank sensor is under that cover, near the TB drive pulley.
I was driving home on highway my car shut down would not start again the engine light flashed 5 times and went off sounds like there is a weak cranking on the bottom where the harmonic balancer is can anyone help thank you
