I just got a 2002 Oddessy and I'm trying to change the oil. I can't find the oil plug. The manual isn't too helpful.
Anyone. please describe in great detail where and which bolt it is?
There is one on the Driver side of the engine that is a square inverted bolt (my socket wrench without any sockets on it, fits in there) that looks like it has a metal washer on it. I thought this was it, but I can't loosen it. It sits between a couple of other 14mm bolts.
Thanks,
Mike
if you have a photo that would be great too...
The one you are describing is the TRANSMISSION drain plug. Don't remove it!
The one you want is on the passenger side, a 17mm hex bolt with its head toward the rear of the van. Its a little hard to see from the side, because there's a frame member or something that sits pretty close to it.
I'll state its about 18" from the outer face of the passenger front tire.
