1 - 6 of 6 Posts
our 2002 had a dead battery ( battery is less than 6 months old) while trying to jump start it cranked weakly a couple of times then stopped. I know the battery is now okay it starts my truck.now it won't crank. any chance the jump attempt blew a relay or fuse?
2003 EX-L
Sure sounds like a loose or corroded battery connection or a bad connection on the starter.
If the dome light dims or goes out while trying to crank the engine, it is most likely a bad connection.
Buffalo
PS: It could also be a failing starter.
2003 EX-L
norcal510 said:
I changed the starter today and forgot to connect the little wire.
I've solved the problem. It was a bad starter.
Thank you
Thanks for posting your solution! :)
I wish more folks would do that because it can help others.
Buffalo4 :D
1 - 6 of 6 Posts
