I just installed a DEI 561R and 556HW in my 2003 Odyssey EX and had several questions. I also wanted to share some of the things I learned in hopes it might help someone else installing a remote start.
My Question
First off, does anyone know where the yel/red wire for the factory hood pin switch is located? 12volt.com states that it is right of steering column but this does not help since I cannot find it.
Also does anyone know the proper way to add a relay to control the power sliding doors with my AUX output? The doors still work on my wife factory remote just not my aftermarket one. I have seen this mention on here before but have been unable to find any diagrams showing how to accomplish using an aftermarket remote with the sliding doors.
The Install
I went with the 561R simply because I found it at a better price than the 561T. It also gave me an extra remote that now I carry on my key chain and my wife has the factory remote. Having the bypass module installed also allows me to be able to use the remote start to start the car then use my cheap $15 key that has no chip in it to drive away. If I use the same key without remote starting first it will only crank and not start.
Obstactles Overcome
Some of the drawbacks I have read where that the 561 would not allow you to unlock or lock your doors during remote start. That is not true. In order to enable this feature you must fool the factory wireless module into believing the car is not running. You can simply cut the yellow wire feeding the factory wireless module. Alternatively and maybe a more correct way is to connect the yellow wire on the H1 primary haness of the 561 module to yellow wire of the factory wireless module. So my install DOES allow the doors to be locked and unlocked with the factory remote during remote start, but it still DOES NOT allow the doors to be locked/unlocked while the key is inserted due to the key sense signal. This is how it should be in my opinion.
The second aspect to my install is that I refused to connect the activation wire of the 561 remote start module directly to the door lock motor. Doing so in my opinion is a huge security risk. Say if I were a theif and I know it is done like this on your car then I can gain access to your car(break window), hit your door lock switch 2-3 times which would then disable your alarm and start your car. All a thief would have to do then is break the ignition switch and take off. I choose to connect the activation wire to the panic output of the factory wireless module. I know that the panic will no longer work, but my wife decided that it would never get used anyways(I know this solution is not for everyone). I could have also just as easily connected it to the lock output of the factory wireless module and it would have been just as secure. My point if you can activate your remote start from your door panel lock switch then that is no good in my opinion.
561 Options I Selected
-Changed the parking lights from flashing to constant
-Changed crank time from 0.6s to 0.8s(thinking about going to 1.0s)
-Changed activation pulses from 2 to 1(triggered by panic button)
-Changed lock/unlock pulses from 1 to 2(does horn confirmation on lock / driver door then all doors on unlock)
-Disabled the lock/unlock with ignition on
Wiring Connection Chart
My Question
The Install
Obstactles Overcome
Code:
[B]Module Vehicle Function Location In Vehicle Notes[/B]
[B]Heavy Gauge Relay Harness[/B]
Pnk Blk/Yel (+) Ignition Brown Con. Behind Driver Kick Panel Fuse Box
Ppl Blk/Wht (+) Start Brown Con. Behind Driver Kick Panel Fuse Box
Org Wht/Blk (+) Accessory Brown Con. Behind Driver Kick Panel Fuse Box
Red Wht (+) 12V Brown Con. Behind Driver Kick Panel Fuse Box
Pnk/Wht Yel (+) Dash Lights Brown Con. Behind Driver Kick Panel Fuse Box
[B]H1 Primary Harness[/B]
Lt Grn/Blk Blu Disarm Driver Door Multiplexer(Behind Window Switches)
Grn/Wht Blu/Wht Arm Driver Door Multiplexer(Behind Window Switches)
Yel Yel (+) Ign Omron Wireless Module Behind Glovebox CUT
Wht/Blu Red/Yel (-) Activation to RX Panic Omron Wireless Module Behind Glovebox CUT
Gry/Blk N/C (-) Wait To Start
Wht/Red N/C (+) Activation
Red/Wht N/C Channel 2
Blk Ground Ground
Wht Red/Yel (+/-) Light Flash Green Con. Behind Driver Kick Panel Fuse Box
[B]H2 Remote Start Harness[/B]
Blk/Wht Ground Neutral Switch
Vlt/Wht Blu Tach Input Test Con. Above Master Cylinder
Brn Wht/Blk (+) Brake Input Green Con. Behind Driver Kick Panel Fuse Box
Gray Yel/Red (-) Hood Input ???
Blu/Wht Org/Blk (-) 2nd Status Output 556HW Bypass Module
[B]Door Lock Harness[/B]
Green Grn/Blu (-) Lock Omron Wireless Module Behind Glovebox
Blue Pnk/Blk (-) Unlock Omron Wireless Module Behind Glovebox
[B]556HW Bypass Harness[/B]
Grn Brn/Blk Reference Connector Left of Steering Col Under Dash
Blu/Wht Blu/Wht Rem Start In to Status Out Remote Start Module
Org/Blk Org/Blu Synch / Data 2 Connector Left of Steering Col Under Dash
Org N/C
Yel Blu/Grn Data ECM Side Connector Left of Steering Col Under Dash CUT
Yel/Blk Blu/Grn Data Key Side Connector Left of Steering Col Under Dash CUT
Pnk/Blk N/C
Blk Ground Ground
