1 - 6 of 6 Posts
whats going on ? My 2003 honda odyssey transmission slips on 2nd but when i disconnect the battery and connect it back again to reset while the check engine light on isnt on it works perfectly ! What could it be ? could it be the whole transmission I need to buy or is it a sensor ?
Did you get the code read for the check engine light? If not sorta hard to tell.
With ours the CEL came on and was p0740. Car drove OK for a month or so and then started to slip in the lower gears. At that point it was done.
As a last ditch effort search around here. Some have been able to clean some screens and change the fluid to prolong its life a bit.
A slip is a warning.
If I may suggest, if you havent done so yet, stop driving the ody til you replace the ATF with synthetic ATF and some Synthetic Racing ATF combo like i did. it will make it last longer.
CK
You could trade it. Otherwise have the codes read and post here. The only way to determine a problem is to get the failure codes from the computer.
And the code could indicate that it is only an electrical circuit failure and not a mechanical one $$$. Get the code.
1 - 6 of 6 Posts
