Thanks so much for your replies, which I'll pass along to my mechanic.I would start eliminating stuff beginning with an alternator load test.
Slowly rev up the engine at idle and listen to it. If there is some kind of hesitation maybe the egr ports clogged.
About your first questions re dash lights: my recollection is that all the dash lights just all go dark initially, but I'm not 100% certain of that and will pay closer attention next time.When it happens does the dash go black or do all the red lights come on? You said no lights but does the dashboard stay powered up? It's sounding electrical to me. What the dash does would dictate to me whether I check ignition switch first or main relay first. See if you can duplicate the problem by gently wiggling the key when it's running. Try pulling down on it, moving it slightly one direction or another, etc. If you can't duplicate it that when then I'd start suspecting main relay.
Again thank you very much for taking the time to assist.I just use symptoms decide where to start. If the dash goes dark that indicates a loss of power to the gauge cluster, and presumably everything else. If it was an egr caused (i.e. big vacuum leak) stall I would expect all the red lights on the cluster to illuminate, as if the key was on but engine not running. If you can't get anything to happen with the ignition switch I'd start looking at that main relay.
HI, I have been recently experiencing a similar problem in my Oddy 2004 with random stalling for a few seconds here and there while driving. The problem seemed to be with my Upstream 02 sensor when it got wet. I noticed my van randomly stalling after a rain fall when driving over water puddles but the day after on a dry day it ran fine. I bought some electronic grease and sealed the 02 sensor connectors and threads. Since then problem went away. I also changed the MAP sensor just to make sure. runs perfect now.2003 Odyssey stalling issue - On intermittent occasions — but sometimes not for days — my 2003 Ody stalls out of nowhere, but only briefly (like for 5-10 seconds) but just enough to need to pull over, put transmission in park and restart the engine. This seems to be happening more and more often, where now on a 6 mile trip in happens 2-3 times. So far, it has always restarted fine and then la-la-la I go again down the road. until next time. The problem seems electrical somehow. but may possibly be a temporary disruption of fuel supply (?). This is accompanied by no dashboard indicator lights going on nor anything else unusual.
I have taken it in twice to my top notch mechanic several times, but he is as puzzled as I am as to what is making this happen, much less how to fix it. I just replaced the battery, so I know it isn’t that.
I have perused this website for others having this problem, but have not seen this issue posted anywhere. Anyone?
Yes, like others said before on this site. It's the ignition switch. When it happens again, try moving the key in all directions then all dash board lights will come back on and car will start automatically if car still in motion. This happened to me several times and finally figured out after searching internet (thanks guys!). I have 2002 Odyssey and have not replaced the ignition yet (please advise if some one know the p/n, thanks).2003 Odyssey stalling issue - On intermittent occasions — but sometimes not for days — my 2003 Ody stalls out of nowhere, but only briefly (like for 5-10 seconds) but just enough to need to pull over, put transmission in park and restart the engine. This seems to be happening more and more often, where now on a 6 mile trip in happens 2-3 times. So far, it has always restarted fine and then la-la-la I go again down the road. until next time. The problem seems electrical somehow. but may possibly be a temporary disruption of fuel supply (?). This is accompanied by no dashboard indicator lights going on nor anything else unusual.
