2003 all of a sudden will not start. Replaced battery and that did not fix it. Before battery replacement all lights and radio worked fine, but replaced battery anyway. No ticking noice in the crank position, just dead. Read on another forum to put it in neutral to get it to start and it worked. But to be fair I had the key in the 'on' position for 15 minutes. Thinking this was the Golden Ticket I thought I was good and went to start it to go home, put it in neutral and did not work. So I left the key in the 'on' position again for 5 minutes shifted it to neutral and it started. But at home that did not work. I shifted it up and down between neutral and park to get it to work and it started in park this time. I've read it could be numerous issue like the neutral safety switch, corroded cables, etc. The van has 290,000 miles on it and thinking it's time to get rid of it and spend the money on a CRV.
Anyone else experience this issue before I give up or spend $$$ on it?
Thank you!
