I can't seem to get a straight answer to my AC problems. My front AC only blows hot air while my back air works fine. Dealer wants to replace compressor/condenser for more than $2000! After searching the web, I am reluctant to believe this will fix my problem. I will pay but I don't want to be out that money and the repair not work. I am in no way a mechanic but it seems if the back air is working maybe something else is amiss. Any suggestions are welcome!
If the rear unit is putting out cold air there is nothing wrong with the compresser/condenser. Both the front and back use the same compresser. Chanses are the air mix control circuit is failing causing the heater air to be transfered through. There are several threads on the subject. I would take it to an independant HVAC repair shop rather than the dealer or find a better Dealer. It could also be the heater valve not transfering. It is on the firewall in the engine compartment.
