When under warranty, two were replaced. Is there a manual lock I can have installed rather than replace these again? I have 120K and otherwise running excellent. Is it advisable to seek a junk dealer for these or are they too delicate to expect to work if not new?
Squirt some lock eeze or other lock lubricant in the locks. That is a common problem on all car locks.
Wow William I never thought of that. (sarcasm alert) I joined this forum to hear about WD 40. Yeah.
Sheesh.
I am 60 and have owned dozens of cars. I have raised engines and replaced many components. These Odyssey electric locks have been continuously a problem; I am simply looking for an alternative to obtaining the part from a dealer. Any one have a suggestion before I buy the kit from Honda??
I believe WW is refering to graphite lube for the lock cylinders and not WD40. The graphite has solved lock problems for some and hence his suggestion.
I think there is a cheap fix to the lock actuators here somewhere on this site. Basically replacing a component of the actuator and not the whole unit.
