Hi Folks,
After a lot of research here, I got my 2004 Odyssey working like a dream with a new Fuel Relay switch. It's been running great until last week, where I started it up, ran it for a bit and let it sit at idle for a bit. When I came back out to shut it off, it had died and wouldn't start again. A new fuel pump later with no luck, I'm struggling to diagnose the issue. Here's what I've done so far:
I hotwired the fuel pump to the driver side set of leads and it spun up, supplying fuel to the system and the van would start. Hotwiring to the top set of leads did nothing as far as I could tell.
Before I start replacing the ignition switch and considering a new relay, what other diagnostics should I run to attempt to find the root cause for replacement?
Thanks!
- Immobilizer is working correctly (green light is behaving as expected after new Relay Switch)
- Ignition switch looks ok to my untrained eye after pulling the steering column apart
- Fuel pump is only getting 5V power on both sets of leads
- Relay is getting 12V
- Fuel pump makes no noise when key switched to on
Thanks!
