Hi!
I am the proud owner of a 2004 Odyssey LX (119K mi!) and have ignored my non-functioning rear vents for long enough. I read through many, many threads and I was ready to bypass the thermistor using the 194LL lamp since many have had good luck with that particular fix. However, when I removed the motor, I noticed that the gears do not turn freely. I removed the small electric motor from it's housing and I just can't seem to get those gears to move more than a millimeter. Granted, I didn't force things too hard, but I thought that they would at least move freely. When I do try to move them, the little piece that connects the motor to the gears makes a small movement, but that's it.
So, my question is whether there is an problem with the actual gear mechanism, or is this normal operation for this unit? Does the motor actually need to be in place for the gears to operate? I could hear the relays click when I tried to use the window switch, so that part seems to work and I just assumed at first that I was having the same issues as everyone else. However, now I'm not so sure.
If anyone could point me in the right direction, I would appreciate it.
Thanks!
Thanks!
