Status
Not open for further replies.
1 - 20 of 25 Posts
2005 Odyssey Technical Service Bulletins (TSB)
TSB 08-031 Warranty Extension: Paint Peeling on Dark Blue 2003–05 Odysseys
Applies To: 2003–05 Odyssey w/Midnight Blue Pearl Paint – ALL VINs Beginning with 5FN
http://www.urvi.net/forumfiles/SB/A08-031.PDF
TSB 08-045 Chirp From the Timing Belt Area
Applies To: 2005–2007 Accord V6 – ALL
2005–2007 Odyssey – ALL
2005–2007 Pilot – ALL
2005 –2007 Ridgeline – ALL
http://www.urvi.net/forumfiles/SB/A08-045.PDF
TSB 06-083 Excessive Engine Vibration at Idle or Below 2,100 RPM
Applies To: 2005–06 Odyssey EX-L – ALL
2005–06 Odyssey Touring – ALL
http://www.urvi.net/forumfiles/SB/A06-083.PDF
TSB 07-005 Power Steering Pump Whines, Buzzes, or Hums
Applies To: 2005–07 Odyssey – ALL
2008 Odyssey – From VIN 5FNRL38..8B000001 thru 5FNRL38..8B075356
2008 Odyssey – From VIN 5FNRL38..8B400001 thru 5FNRL38..8B419525
http://www.urvi.net/forumfiles/SB/A07-005.PDF
TSB 07-020 Safety Recall: Fuel Pump Relay May Cause Engine No-Start or Stalling
Applies To: 2005 Odyssey:
From VIN 5FNRL38..5B092182 thru
5FNRL38..5B123756
From VIN 5FNRL38..5B413956 thru
5FNRL38..5B421996
http://www.urvi.net/forumfiles/SB/A07-020.PDF
TSB 07-023 Driver’s Power Seat Doesn’t Move Forward or Backward
Applies To: 2005–06 Odyssey (except LX)
2007 Odyssey (except LX) – From VIN 5FNRL3...7B000001 thru 5FNRL3...7B026590
2007 Odyssey (except LX) – From VIN 5FNRL3...7B400001 thru 5FNRL3...7B420216
2006 Ridgeline – From VIN 2HJYK1...6H500001 thru 2HJYK1...6H519353
http://www.urvi.net/forumfiles/SB/A07-023.PDF
TSB 07-028 Pinging, Rattling, or Squealing During Light Acceleration
Applies To: 2005–06 Odyssey: ALL
2007 Odyssey:
thru 5FNRL3...7B007592
thru 5FNRL3...7B405900
http://www.urvi.net/forumfiles/SB/A07-028.PDF
TSB 07-067 Rear Entertainment System DVD Does Not Load, Play, or Eject
2006–07 Pilot – ALL
http://www.urvi.net/forumfiles/SB/A07-067.PDF
TSB 07-084 RES Headphones Don’t Work in DVD Mode
Applies To: 2005–07 Odyssey – All Models With Rear Entertainment System
http://www.urvi.net/forumfiles/SB/A07-084.PDF
TSB 06-003 Power Sliding Door Squeaks, Creaks, Rattles, Clunks, or Pops
Applies To: 2005–06 Odyssey EX and Touring Models – ALL
http://www.urvi.net/forumfiles/SB/A06-003.PDF
TSB 06-004 SRS Indicator Comes On With DTC B2-11 or B2-84
Applies To: 2005 Odyssey – ALL
2006 Odyssey – From VIN 5FNRL3...6B000001 thru 5FNRL3...6B018561
2006 Odyssey – From VIN 5FNRL3...6B400001 thru 5FNRL3...6B405183
http://www.urvi.net/forumfiles/SB/A06-004.PDF
TSB 06-018 Bearing Noise From the Front Wheels
2006 Odyssey – 5FNRL3...6B000001 thru 5FNRL3...6B012830
2006 Odyssey – 5FNRL3...6B400001 thru 5FNRL3...6B403543
http://www.urvi.net/forumfiles/SB/A06-018.PDF
TSB 06-024 Front Brakes Groan at Low Speeds
2006 Odyssey – From VIN 5FNRL38..6B000001 thru 5FNRL38..6B106388
2006 Odyssey – From VIN 5FNRL38..6B400001 thru 5FNRL38..6B443036
http://www.urvi.net/forumfiles/SB/A06-024.PDF
TSB 06-048 MIL Comes On With DTC P0116
Applies To: 2005–06 Odyssey – ALL
http://www.urvi.net/forumfiles/SB/A06-048.PDF
TSB 06-050 Drone or Moan When Driving at 2,100 RPM
http://www.urvi.net/forumfiles/SB/A06-050.PDF
TSB 06-068 Vehicle Pulling or Drifting
Applies To: ALL
http://www.urvi.net/forumfiles/SB/A06-068.PDF
TSB 06-072 TPMS Sensor Tool Usage
Applies To: 2007–08 Odyssey – ALL except Touring
http://www.urvi.net/forumfiles/SB/A06-072.PDF
TSB 06-085 Warranty Extension: Vehicle Warranty Mileage
Applies To: certain 2002 through
2006 Honda models
http://www.urvi.net/forumfiles/SB/A06-085.PDF
TSB 05-001 2005 Honda Paint Codes
Applies To: 2005 Models – ALL
http://www.urvi.net/forumfiles/SB/A05-001.PDF
TSB 05-008 MIL Comes On With DTC P1659
Applies To: 2005 Odyssey – From VIN 5FNRL3...5B000001 thru 5FNRL3...5B059257
2005 Odyssey – From VIN 5FNRL3...5B400001 thru 5FNRL3...5B406226
http://www.urvi.net/forumfiles/SB/A05-008.PDF
TSB 05-011 Power Sliding Door(s) Do Not Work, and DTCs B2038 and/or B2088 Are Set
Applies To: 2005 Odyssey – From VIN 5FNRL3...5B000001 thru 5FNRL3...5B065696
VIN 5FNRL3...5B400001 thru 5FNRL3...5B408107
http://www.urvi.net/forumfiles/SB/A05-011.PDF
TSB 05-012 Moonroof Glass Weatherstrip Is Damaged
Applies To: 2005–07 Odyssey: ALL
http://www.urvi.net/forumfiles/SB/A05-012.PDF
TSB 05-014 Safety Recall: Fuse Box May Cause a No-Start or Stalling Condition
Applies To: 2005 Accord L4 2-Door – From VIN 1HGCM71..5A007928 thru 1HGCM71..5A008407
From VIN 1HGCM72..5A007883 thru 1HGCM72..5A008347
2005 Accord V6 2-Door – From VIN 1HGCM81..5A006275 thru 1HGCM81..5A006334
From VIN 1HGCM82..5A006035 thru 1HGCM82..5A006394
2005 Odyssey – From VIN 5FNRL38..5B030578 thru 5FNRL38..5B042841
http://www.urvi.net/forumfiles/SB/A05-014.PDF
TSB 05-016 Child Seat Anchor Locating Button Is Missing
Applies To: 2001–05 Odyssey – ALL
http://www.urvi.net/forumfiles/SB/A05-016.PDF
TSB 05-019 MIL Comes On With DTC P2647
Applies To: 2005 Odyssey EX-L and Touring – 5FNRL38..5B000001 thru 5FNRL38..5B057626
2005 Odyssey EX-L and Touring – 5FNRL386.5B400001 thru 5FNRL386.5B406585
http://www.urvi.net/forumfiles/SB/A05-019.PDF
TSB 05-031 Alaska-only Product Update: Replace ETCS, Starter Cut, and
A/F Sensor Relay
Applies To: 2005 Odyssey – See Vehicles Affected (45 sold in Alaska)
http://www.urvi.net/forumfiles/SB/A05-031.PDF
TSB 05-032 Navigation System DVD Information and Inspection
Applies To: 2000–08 Odyssey
http://www.urvi.net/forumfiles/SB/A05-032.PDF
TSB 05-034 Headlights Dim or DTC P1298 Is Stored in the ECM/PCM
From VIN 5FNRL38..5B000001 thru
5FNRL38..5B018359
http://www.urvi.net/forumfiles/SB/A05-034.PDF
TSB 05-035 Safety Recall: Front Impact Sensor Corrosion Causes the SRS Indicator to Stay On
Applies To: 2005 Odyssey – From VIN 5FNRL38..5B400001 thru 5FNRL38..5B409694
From VIN 5FNRL38..5B000001 thru 5FNRL38..5B075678
http://www.urvi.net/forumfiles/SB/A05-035.PDF
TSB 05-036 Product Update: Front Door Inner Handle Cable Freezes, Wire Harness Connectors Need More Dielectric Grease
Applies To: 2005 Odyssey – See VEHICLES AFFECTED
http://www.urvi.net/forumfiles/SB/A05-036.PDF
TSB 05-037 Product Update: MIL Comes On With DTC P2647
– From VIN 5FNRL38..5B000001 thru 5FNRL38..5B057596
– From VIN 5FNRL38..5B400001 thru 5FNRL38..5B406580
http://www.urvi.net/forumfiles/SB/A05-037.PDF
TSB 05-049 No Sound From RES Headphones
Applies To: 2005 Odyssey with Rear Entertainment System – ALL
http://www.urvi.net/forumfiles/SB/A05-049.PDF
TSB 05-068 Product Improvement Campaign: Tire Valve Cap Replacement
Applies To: 2005 Odyssey Touring – ALL
2006 Odyssey Touring – From VIN 5FNRL388.6B000001 thru 5FNRL388.6B010540
2005 Pilot – From VIN 2HKYF18..5H500001 thru 2HKYF18..5H571501
2005 Pilot – From VIN 5FNYF18..5B000001 thru 5FNYF18..5B067307
2006 Ridgeline – From VIN 2HJYK16..6H500001 thru 2HJYK16..6H535591
http://www.urvi.net/forumfiles/SB/A05-068.PDF
TSB 05-072 PCM Software Outputs Incorrect Readiness Code Status
Applies To: 2005 Odyssey EX-L and Touring – ALL
http://www.urvi.net/forumfiles/SB/A05-072.PDF
TSB #08-084 Time on Display Changes Randomly
Applies To: 2005–09 Odyssey with Navigation – ALL
http://www.urvi.net/forumfiles/SB/A08-084.PDF
TSB #08-078 Electrical Problems and B-CAN DTCs After Exposure to Water/Water Leaks
Applies To: 2005-2009 Odysseys
http://www.urvi.net/forumfiles/SB/A08-078.PDF
TSB #08-088 Service Manual Update: Poor AM or FM Reception
Applies To: ALL 2004–09 Models
http://www.urvi.net/forumfiles/SB/A08-088.PDF
TSB # 09-042 Damaged Camshaft Position Sensor (CMP) Causes the MIL to Come On With DTC P0344
http://www.urvi.net/forumfiles/SB/A09-042.PDF
Power Sliding Door Stops at Half-Latch Position, Won’t Close
Currently Applies To: ’05–09 Odyssey
http://www.urvi.net/forumfiles/SN/A09060t.pdf
Rear Wheels Howl or Moan When Braking
http://www.urvi.net/forumfiles/SN/A09060o.pdf
TSB # 10-006 2005-06 Odyssey: MIL Comes On With DTC P0171
Applies To: 2005-06 Odyssey EX-L/EX-L Touring with J35A7 (VCM) engine – ALL
http://www.urvi.net/forumfiles/SB/A10-006.PDF
TSB # 09-051 Windshield Side Trim Retainer Is Loose or Broken
Applies To: 2005–10 Odyssey – ALL
http://www.urvi.net/forumfiles/SB/A09-051.PDF
SEE MY NEXT POST FOR MORE TSBs FOR THIS MODEL...
TSB # 10-011 Service Manual Update: Power Window Goes Up and Reverses On Its Own,
Is Slow to Open and Close, or Squeals, Creaks, Clunks, or Clicks
VEHICLES AFFECTED: 2005–10 Odyssey – ALL
http://www.urvi.net/forumfiles/SB/A10-011.PDF
TSB # 10-014 Product Improvement Campaign: Power Tailgate May Not Stay Open
Applies To: 2005 Odyssey EX-L Touring – From VIN 5FNRL388.5B000325 thru
5FNRL388.5B133626
http://www.urvi.net/forumfiles/SB/A10-014.PDF
TSB 10-069 - Safety Recall: Master Cylinder May Be Leaking
2005 Odyssey
FromVIN 5FNRL3...5B000146
thru 5FNRL3...5B136928
FromVIN 5FNRL3...5B400014
thru 5FNRL3...5B425597
VIN 5FNRL3...5B503419
FromVIN 5FNRL4...5B129215
thru 5FNRL4...5B129244
2006 Odyssey
FromVIN 5FNRL3...6B000001
thru 5FNRL3...6B129961
FromVIN 5FNRL3...6B400001
thru 5FNRL3...6B463199
2007 Odyssey
FromVIN 5FNRL3...7B000201
thru 5FNRL3...7B068053
FromVIN 5FNRL3...7B400201
thru 5FNRL3...7B441549
http://www.urvi.net/forumfiles/SB/A10-069.PDF
TSB 10-076 - Steering Wheel Is Hard to Turn Quickly at Low Speeds
http://www.urvi.net/forumfiles/SB/A10-076.PDF
TSB 11-039 Warranty Extension: Steering Wheel Is Hard to Turn at Low Speeds
Applies To: 2005 Odyssey – Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A11-039.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A11-039.PDF
TSB 09-054 - Power Door Locks Continually Lock While Driving
Applies To: 2005–06 Odyssey – Touring models only
2007–09 Odyssey – ALL
http://www.urvi.net/forumfiles/SB/A09-054.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A09-054.PDF
TSB 12-029 - Warranty Extension: PCM Update for Lock-Up Clutch Function
Applies To: 2005–06 Odyssey EX-L and EX-L Touring – Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A12-029.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A12-029.PDF
TSB 14-015 - Safety Recall: Odyssey Fuel Smell or Leak
Applies To: 2005–10 Odyssey – ALL – Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A14-015.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A14-015/enu/A14-015.PDF
TSB 14-032 - Safety Recall: Odyssey Fuel Pump
Applies To: 2005-10 Odyssey - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A14-032.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A14-032/enu/A14-032.PDF
TSB 19-111 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram
Applies To: 2005-17 Odyssey
http://www.urvi.net/forumfiles/SB/A19-111.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-111/enu/A19-111.PDF
New Dad,
Thanks for putting all that together. As a new owner of an '05 Odyssey, its extremely helpful.
I'm having an issue with my '05 that I found a TSB for on Edmunds, but I didn't see it on your list.
"Summary:
30-45 MPH WHISTLING AT THE A PILLAR. ( NHTSA ITEM NUMBER - 10018168 )"
Are you also able to find a link to this TSB?
Thanks for your help.
thanks for the links, i'm gonna use some of these the next time i go to the dealer and they tell me that "droning is normal and that vibration, we don't feel any vibration/ shudder"
What is one supposed to do or how do i find out if this work has been done to my 05 Oddy Touring? I bought it a year ago. Could i just ask the dealership to look into it? I feel like they will lie & say yeah its been done, lol.
Discussion Starter · #7 ·
For the Safety Recalls, call the dealer with your VIN # and they should have a record. The Safety Recalls above list the VIN # ranges for you - just compare with yours.
As for the TSBs, if you have any of these symptoms, these will assist you and the dealer in a resolution.
If you provide all at once, I'm sure you'll get some reaction.
Discussion Starter · #8 ·
Discussion Starter · #9 ·
Discussion Starter · #10 ·
Error when loading TSBs
I am getting the following error when trying to access the TSBs posted in this thread.
Is anyone else getting this message?
You are not authorized to view the content on this page.
If you believe you have received this message in error, please contact the Support Center.
Please go back or return to the home page.
They became unavailable a few months back, I think. You can usually find them by searching for the "honda [TSB name, such as A10-014.PDF]" in Google.
Alternatively, you can get the 10$ 3 days subscription to the tech service site and get them.
As an aside, where are you in Quebec? We are in Montreal and bought our 07 EX-L in April.
Nicolas
Thanks
Thanks for the tip nico but it`s too bad that Honda doesn`t just post them in the public domain...I guess $10 isn`t too bad.
We are in Gatineau and just recently bought a 2005 EX-L to accommodate the growing family.
My wife`s parents are in Quebec City so we end up coming through Montreal a lot...beautiful city but I have to admit that I find the traffic a bit hairy at times.
Have you lived in Montreal for a long time?
All the best.
Pm sent. :)
· Administrator
Posted updated links. Not all TSBs were salvaged. Please report missing ones and if you have the missing ones, I'd appreciate a copy.
· Administrator
cruiserman said:
Can't find these 2:
thanks
Still looking for A05-049.PDF but the A09060o.pdf should be up. :)
Try the link again.
1 - 20 of 25 Posts
Status
