2005 Odyssey Technical Service Bulletins (TSB)
TSB 08-031 Warranty Extension: Paint Peeling on Dark Blue 2003–05 Odysseys
Applies To: 2003–05 Odyssey w/Midnight Blue Pearl Paint – ALL VINs Beginning with 5FN
http://www.urvi.net/forumfiles/SB/A08-031.PDF
TSB 08-045 Chirp From the Timing Belt Area
Applies To: 2005–2007 Accord V6 – ALL
2005–2007 Odyssey – ALL
2005–2007 Pilot – ALL
2005 –2007 Ridgeline – ALL
http://www.urvi.net/forumfiles/SB/A08-045.PDF
TSB 06-083 Excessive Engine Vibration at Idle or Below 2,100 RPM
Applies To: 2005–06 Odyssey EX-L – ALL
2005–06 Odyssey Touring – ALL
http://www.urvi.net/forumfiles/SB/A06-083.PDF
TSB 07-005 Power Steering Pump Whines, Buzzes, or Hums
Applies To: 2005–07 Odyssey – ALL
2008 Odyssey – From VIN 5FNRL38..8B000001 thru 5FNRL38..8B075356
2008 Odyssey – From VIN 5FNRL38..8B400001 thru 5FNRL38..8B419525
http://www.urvi.net/forumfiles/SB/A07-005.PDF
TSB 07-020 Safety Recall: Fuel Pump Relay May Cause Engine No-Start or Stalling
Applies To: 2005 Odyssey:
From VIN 5FNRL38..5B092182 thru
5FNRL38..5B123756
From VIN 5FNRL38..5B413956 thru
5FNRL38..5B421996
http://www.urvi.net/forumfiles/SB/A07-020.PDF
TSB 07-023 Driver’s Power Seat Doesn’t Move Forward or Backward
Applies To: 2005–06 Odyssey (except LX)
2007 Odyssey (except LX) – From VIN 5FNRL3...7B000001 thru 5FNRL3...7B026590
2007 Odyssey (except LX) – From VIN 5FNRL3...7B400001 thru 5FNRL3...7B420216
2006 Ridgeline – From VIN 2HJYK1...6H500001 thru 2HJYK1...6H519353
http://www.urvi.net/forumfiles/SB/A07-023.PDF
TSB 07-028 Pinging, Rattling, or Squealing During Light Acceleration
Applies To: 2005–06 Odyssey: ALL
2007 Odyssey:
thru 5FNRL3...7B007592
thru 5FNRL3...7B405900
http://www.urvi.net/forumfiles/SB/A07-028.PDF
TSB 07-067 Rear Entertainment System DVD Does Not Load, Play, or Eject
2006–07 Pilot – ALL
http://www.urvi.net/forumfiles/SB/A07-067.PDF
TSB 07-084 RES Headphones Don’t Work in DVD Mode
Applies To: 2005–07 Odyssey – All Models With Rear Entertainment System
http://www.urvi.net/forumfiles/SB/A07-084.PDF
TSB 06-003 Power Sliding Door Squeaks, Creaks, Rattles, Clunks, or Pops
Applies To: 2005–06 Odyssey EX and Touring Models – ALL
http://www.urvi.net/forumfiles/SB/A06-003.PDF
TSB 06-004 SRS Indicator Comes On With DTC B2-11 or B2-84
Applies To: 2005 Odyssey – ALL
2006 Odyssey – From VIN 5FNRL3...6B000001 thru 5FNRL3...6B018561
2006 Odyssey – From VIN 5FNRL3...6B400001 thru 5FNRL3...6B405183
http://www.urvi.net/forumfiles/SB/A06-004.PDF
TSB 06-018 Bearing Noise From the Front Wheels
2006 Odyssey – 5FNRL3...6B000001 thru 5FNRL3...6B012830
2006 Odyssey – 5FNRL3...6B400001 thru 5FNRL3...6B403543
http://www.urvi.net/forumfiles/SB/A06-018.PDF
TSB 06-024 Front Brakes Groan at Low Speeds
2006 Odyssey – From VIN 5FNRL38..6B000001 thru 5FNRL38..6B106388
2006 Odyssey – From VIN 5FNRL38..6B400001 thru 5FNRL38..6B443036
http://www.urvi.net/forumfiles/SB/A06-024.PDF
TSB 06-048 MIL Comes On With DTC P0116
Applies To: 2005–06 Odyssey – ALL
http://www.urvi.net/forumfiles/SB/A06-048.PDF
TSB 06-050 Drone or Moan When Driving at 2,100 RPM
http://www.urvi.net/forumfiles/SB/A06-050.PDF
TSB 06-068 Vehicle Pulling or Drifting
Applies To: ALL
http://www.urvi.net/forumfiles/SB/A06-068.PDF
TSB 06-072 TPMS Sensor Tool Usage
Applies To: 2007–08 Odyssey – ALL except Touring
http://www.urvi.net/forumfiles/SB/A06-072.PDF
TSB 06-085 Warranty Extension: Vehicle Warranty Mileage
Applies To: certain 2002 through
2006 Honda models
http://www.urvi.net/forumfiles/SB/A06-085.PDF
TSB 05-001 2005 Honda Paint Codes
Applies To: 2005 Models – ALL
http://www.urvi.net/forumfiles/SB/A05-001.PDF
TSB 05-008 MIL Comes On With DTC P1659
Applies To: 2005 Odyssey – From VIN 5FNRL3...5B000001 thru 5FNRL3...5B059257
2005 Odyssey – From VIN 5FNRL3...5B400001 thru 5FNRL3...5B406226
http://www.urvi.net/forumfiles/SB/A05-008.PDF
TSB 05-011 Power Sliding Door(s) Do Not Work, and DTCs B2038 and/or B2088 Are Set
Applies To: 2005 Odyssey – From VIN 5FNRL3...5B000001 thru 5FNRL3...5B065696
VIN 5FNRL3...5B400001 thru 5FNRL3...5B408107
http://www.urvi.net/forumfiles/SB/A05-011.PDF
TSB 05-012 Moonroof Glass Weatherstrip Is Damaged
Applies To: 2005–07 Odyssey: ALL
http://www.urvi.net/forumfiles/SB/A05-012.PDF
TSB 05-014 Safety Recall: Fuse Box May Cause a No-Start or Stalling Condition
Applies To: 2005 Accord L4 2-Door – From VIN 1HGCM71..5A007928 thru 1HGCM71..5A008407
From VIN 1HGCM72..5A007883 thru 1HGCM72..5A008347
2005 Accord V6 2-Door – From VIN 1HGCM81..5A006275 thru 1HGCM81..5A006334
From VIN 1HGCM82..5A006035 thru 1HGCM82..5A006394
2005 Odyssey – From VIN 5FNRL38..5B030578 thru 5FNRL38..5B042841
http://www.urvi.net/forumfiles/SB/A05-014.PDF
TSB 05-016 Child Seat Anchor Locating Button Is Missing
Applies To: 2001–05 Odyssey – ALL
http://www.urvi.net/forumfiles/SB/A05-016.PDF
TSB 05-019 MIL Comes On With DTC P2647
Applies To: 2005 Odyssey EX-L and Touring – 5FNRL38..5B000001 thru 5FNRL38..5B057626
2005 Odyssey EX-L and Touring – 5FNRL386.5B400001 thru 5FNRL386.5B406585
http://www.urvi.net/forumfiles/SB/A05-019.PDF
TSB 05-031 Alaska-only Product Update: Replace ETCS, Starter Cut, and
A/F Sensor Relay
Applies To: 2005 Odyssey – See Vehicles Affected (45 sold in Alaska)
http://www.urvi.net/forumfiles/SB/A05-031.PDF
TSB 05-032 Navigation System DVD Information and Inspection
Applies To: 2000–08 Odyssey
http://www.urvi.net/forumfiles/SB/A05-032.PDF
TSB 05-034 Headlights Dim or DTC P1298 Is Stored in the ECM/PCM
From VIN 5FNRL38..5B000001 thru
5FNRL38..5B018359
http://www.urvi.net/forumfiles/SB/A05-034.PDF
TSB 05-035 Safety Recall: Front Impact Sensor Corrosion Causes the SRS Indicator to Stay On
Applies To: 2005 Odyssey – From VIN 5FNRL38..5B400001 thru 5FNRL38..5B409694
From VIN 5FNRL38..5B000001 thru 5FNRL38..5B075678
http://www.urvi.net/forumfiles/SB/A05-035.PDF
TSB 05-036 Product Update: Front Door Inner Handle Cable Freezes, Wire Harness Connectors Need More Dielectric Grease
Applies To: 2005 Odyssey – See VEHICLES AFFECTED
http://www.urvi.net/forumfiles/SB/A05-036.PDF
TSB 05-037 Product Update: MIL Comes On With DTC P2647
– From VIN 5FNRL38..5B000001 thru 5FNRL38..5B057596
– From VIN 5FNRL38..5B400001 thru 5FNRL38..5B406580
http://www.urvi.net/forumfiles/SB/A05-037.PDF
TSB 05-049 No Sound From RES Headphones
Applies To: 2005 Odyssey with Rear Entertainment System – ALL
http://www.urvi.net/forumfiles/SB/A05-049.PDF
TSB 05-068 Product Improvement Campaign: Tire Valve Cap Replacement
Applies To: 2005 Odyssey Touring – ALL
2006 Odyssey Touring – From VIN 5FNRL388.6B000001 thru 5FNRL388.6B010540
2005 Pilot – From VIN 2HKYF18..5H500001 thru 2HKYF18..5H571501
2005 Pilot – From VIN 5FNYF18..5B000001 thru 5FNYF18..5B067307
2006 Ridgeline – From VIN 2HJYK16..6H500001 thru 2HJYK16..6H535591
http://www.urvi.net/forumfiles/SB/A05-068.PDF
TSB 05-072 PCM Software Outputs Incorrect Readiness Code Status
Applies To: 2005 Odyssey EX-L and Touring – ALL
http://www.urvi.net/forumfiles/SB/A05-072.PDF
TSB #08-084 Time on Display Changes Randomly
Applies To: 2005–09 Odyssey with Navigation – ALL
http://www.urvi.net/forumfiles/SB/A08-084.PDF
TSB #08-078 Electrical Problems and B-CAN DTCs After Exposure to Water/Water Leaks
Applies To: 2005-2009 Odysseys
http://www.urvi.net/forumfiles/SB/A08-078.PDF
TSB #08-088 Service Manual Update: Poor AM or FM Reception
Applies To: ALL 2004–09 Models
http://www.urvi.net/forumfiles/SB/A08-088.PDF
TSB # 09-042 Damaged Camshaft Position Sensor (CMP) Causes the MIL to Come On With DTC P0344
http://www.urvi.net/forumfiles/SB/A09-042.PDF
Power Sliding Door Stops at Half-Latch Position, Won’t Close
Currently Applies To: ’05–09 Odyssey
http://www.urvi.net/forumfiles/SN/A09060t.pdf
Rear Wheels Howl or Moan When Braking
http://www.urvi.net/forumfiles/SN/A09060o.pdf
TSB # 10-006 2005-06 Odyssey: MIL Comes On With DTC P0171
Applies To: 2005-06 Odyssey EX-L/EX-L Touring with J35A7 (VCM) engine – ALL
http://www.urvi.net/forumfiles/SB/A10-006.PDF
TSB # 09-051 Windshield Side Trim Retainer Is Loose or Broken
Applies To: 2005–10 Odyssey – ALL
http://www.urvi.net/forumfiles/SB/A09-051.PDF
SEE MY NEXT POST FOR MORE TSBs FOR THIS MODEL...
5FNRL38..5B123756
5FNRL38..5B421996
2007 Odyssey:
2006–07 Pilot – ALL
Applies To: ALL
2006 Honda models
A/F Sensor Relay
5FNRL38..5B018359
