I searched this forum and found a few threads on this topic, but none of the solutions worked for me. Here's the problem:
The front right turn signal bulb does not flash when activated by the turn signal switch, nor when the hazard lights are on. The rear right turn signal bulb works fine. The green right turn signal indicator arrow lamp on the dashboard flashes fast.
Here's what I tried:
* Swapped bulb with a known good bulb
* Swapped bulb receptacles
* Replaced turn signal relay with new relay
* Cleaned ground wire connectors located to the right of the radiator
None of these things fixed the problem. :huh: Does anyone have a electrical schematic that can be used to troubleshoot this ?
Thanks.
Thanks.
