1 - 12 of 12 Posts
2005 Odyssey Touring Ed. right at 90k miles. Excellent condition. Never any problem - always serviced by Honda. A few weeks ago I noticed a strange vibration when starting off and especially when going in and out of Econ mode. Much more noticeable when A/C is on. Not just vibration, even exhaust sounds a little louder. Took it to Honda dealer and after looking at it, they said 2 motor mounts were bad - the front hydraulic one and another. They replaced them at cost of $1152. Got van back and it seems exactly the same to me. I have already been back once to put them on notice. My dad says I am an idiot for falling for the motor mount scam. I want to take it somewhere else to find out what is really wrong before going back to dealer and asking for my money back. Any Ideas?
I'm glad to see this post because my 2005 EXL has been doing the same thing for almost a year. When I took it in for a service and I mentioned it, they told me after looking it was a cracked rear motor mount and was going to cost $667 to fix it. I haven't had it fixed yet but I will be in the next few weeks.
Discussion Starter #4
I just wanted to give everyone a heads up on this issue since it seems to be a regular issue. I gave my local Honda dealer one more shot. They found that the remaining motor mount was bad as well and offered to replace it at no charge. I was pleasantly surprised that this was the fix. So to sum it all up - 3 bad motor mounts caused the whole issue. I really was thinking it was some sort of an electrical issue. Van drives perfectly now and I am planning on putting another 90k miles on it!
About what speed was this happening? I have the same issue on my 2005 T at about 40-50 on very light acceleration.
Discussion Starter #7
There was a vibration when slowly accelerating, between 35-40, 45-50, and when ever switching to ECO mode. I could not only fell this vibration in the steering wheel, but in the brake pedal (while at a stop), and in my seat. The exhaust also sounded louder.
Were the first 2 motor mounts roughly $750 and $300? If so, I must say that the dealer can't be that bad if they replaced the 3rd engine mount for free.
My dealer wanted to charge me close about $1700 for all 3 mounts before I called American Honda and was told the 3 motor mounts are covered under the drive train warranty.
Discussion Starter #9
Correct - the first 2 were $1158. One was the active motor mount. I think the last one they replaced was the rear one.
I'm having the same kind of issue with my '03 EX-L RES. I've had it in to the dealer twice about the vibration/shudder, checked suspension and balanced wheels (twice now). I know our roads are bad, but it's consistent between about 45 and 60 mph - at 70 on the interstate it's pretty smooth. The other thing I've noticed is that if I drop from D down to D3 so the engine is pulling higher RPMs, the vibration smooths out - which makes me think that the hydraulic motor mounts may be bad. I read somewhere online that some of the mounts have an electronic control for the damping, so wondered if at the higher RPM it switches to a mode that has better control? Any advice you all can share would be great - I only have 165k on this baby, and not ready to give her up just yet! BTW, the dealer did tell me when I had the timing belt & water pump replaced about 6 mos ago that two of the mounts were worn and needed replaced...just couldn't afford to drop another grand on top of the timing belt & water pump.
Just had my 2005 touring into the dealer. They updated the transmission software and the issue went away completely. Thay said the engine mounts were fine. $100 later and problem solved. I have put over 1000k miles on it and no problems.
1 - 12 of 12 Posts
