1 - 11 of 11 Posts
Hi,While driving suddenly last weekend washer fluid stopped working. I cleaned the nozzle with tooth brush and in-vain. Checked the fluid level, its pretty full I can see the washer fluid is there.
I don't hear any sound (pump sound etc) when I operate the washer fluid.
Any thoughts to find the cause and resolution. Appreciate in advance. Thanks
Administrator
Did you check the fuses?
Forgot to mention I had windshield changed before this problem. Just called up windshield guy and got to know he might have forgot to connect..something. taking car to him this saturday. Will update what happens next. Thanks for reading.
Apparently washer fluid connector pipe not required to remove in 2005 Ody as its mounted on hood. Not sure whats the problem, afraid to take it to the dealer, always bumps with more problems and big money. When i push for washer fluid,don't hear motor sound also.
Would like to know from experts here, fuse down or motor down. I opened the fuse box,couldn't find if fuses blown..any thoughts.
Thanks and sorry for asking basic questions, i'm just started exploring things.
thanks in advance and happy holidays !
Discussion Starter · #8 ·
It's around 30s in Colimbus OH. Other day I drove 400 miles and still it didn't work. I thought same earlier but should have melted after long drive right. I Own this vehicle last 1 month & don't know what has been put earlier. Thanks
the line from the pump goes under the cowl (sort of near the passenger side hood hinge) then comes out and goes up to the hood - when we had the cowl replaced on our van (an 05 EX) they weren't paying attention and pinched the tubing, cutting off flow to the nozzles.
The Owner's Manual would have the windshield washer pump fuse location.
1 - 11 of 11 Posts
