2006 HONDA ODYSSEY - Sunroof Lower Drain Tubing
Can you please help. The Drivers Side A Pillar Sunroof drain pipe/tube is splt and leaking badly nto the drivers side floor. Apparently this pipe is no longer available for a Honda Odyssey 2006 as a spare part, although Honda replaced the same problem on the passenger's side, 12 months ago, when the part was available
We obviously need to find a rubber tubing that extends from the base of the A Pillar around the dashboard that extends to the rear exist point at the rear of the front guard.
Does anyone know the diameter of this rubber pipe, so as I can source it ? Thanks
Lindsay
Email: [email protected]
Hood Automotive lighting Automotive tire Motor vehicle Automotive design
Discussion Starter · #2 ·
Lindsay
2006 Honda Odyssey (EX)
You've already posted on three separate occasions for your issue. No need to post again. And I would remove your e-mail from the public forum. It invites spam.
Probably need to remove that tube and measure it. (or measure the inside diameter at the bottom drain location.) Before you pull it out, attach a string or wire so that you can route your replacement.
(Multiple posts for the same issue do not return an answer faster! And click the 3 dots on the right corner of your posts to choose Edit and remove your spambait email addresses as WiiMaster suggested.)
