Status
Not open for further replies.
1 - 20 of 33 Posts
2006 Odyssey Technical Service Bulletins (TSB)
TSB 08-045 Chirp From the Timing Belt Area
Applies To: 2005–2007 Accord V6 – ALL
2005–2007 Odyssey – ALL
2005–2007 Pilot – ALL
200 –2007 Ridgeline – ALL
http://www.urvi.net/forumfiles/SB/A08-045.PDF
TSB 06-083 Excessive Engine Vibration at Idle or Below 2,100 RPM
Applies To: 2005–06 Odyssey EX-L – ALL
2005–06 Odyssey Touring – ALL
http://www.urvi.net/forumfiles/SB/A06-083.PDF
TSB 07-005 Power Steering Pump Whines, Buzzes, or Hums
Applies To: 2005–07 Odyssey – ALL
2008 Odyssey – From VIN 5FNRL38..8B000001 thru 5FNRL38..8B075356
2008 Odyssey – From VIN 5FNRL38..8B400001 thru 5FNRL38..8B419525
http://www.urvi.net/forumfiles/SB/A07-005.PDF
TSB 07-023 Driver’s Power Seat Doesn’t Move Forward or Backward
Applies To: 2005–06 Odyssey (except LX)
2007 Odyssey (except LX) – From VIN 5FNRL3...7B000001 thru 5FNRL3...7B026590
2007 Odyssey (except LX) – From VIN 5FNRL3...7B400001 thru 5FNRL3...7B420216
2006 Ridgeline – From VIN 2HJYK1...6H500001 thru 2HJYK1...6H519353
http://www.urvi.net/forumfiles/SB/A07-023.PDF
TSB 07-028 Pinging, Rattling, or Squealing During Light Acceleration
Applies To: 2005–06 Odyssey: ALL
2007 Odyssey:
thru 5FNRL3...7B007592
thru 5FNRL3...7B405900
http://www.urvi.net/forumfiles/SB/A07-028.PDF
TSB 07-067 Rear Entertainment System DVD Does Not Load, Play, or Eject
2006–07 Pilot – ALL
http://www.urvi.net/forumfiles/SB/A07-067.PDF
TSB 07-084 RES Headphones Don’t Work in DVD Mode
Applies To: 2005–07 Odyssey – All Models With Rear Entertainment System
http://www.urvi.net/forumfiles/SB/A07-084.PDF
TSB 06-003 Power Sliding Door Squeaks, Creaks, Rattles, Clunks, or Pops
Applies To: 2005–06 Odyssey EX and Touring Models – ALL
http://www.urvi.net/forumfiles/SB/A06-003.PDF
TSB 06-004 SRS Indicator Comes On With DTC B2-11 or B2-84
Applies To: 2005 Odyssey – ALL
2006 Odyssey – From VIN 5FNRL3...6B000001 thru 5FNRL3...6B018561
2006 Odyssey – From VIN 5FNRL3...6B400001 thru 5FNRL3...6B405183
http://www.urvi.net/forumfiles/SB/A06-004.PDF
TSB 06-018 Bearing Noise From the Front Wheels
2006 Odyssey – 5FNRL3...6B000001 thru 5FNRL3...6B012830
2006 Odyssey – 5FNRL3...6B400001 thru 5FNRL3...6B403543
http://www.urvi.net/forumfiles/SB/A06-018.PDF
TSB 06-024 Front Brakes Groan at Low Speeds
2006 Odyssey – From VIN 5FNRL38..6B000001 thru 5FNRL38..6B106388
2006 Odyssey – From VIN 5FNRL38..6B400001 thru 5FNRL38..6B443036
http://www.urvi.net/forumfiles/SB/A06-024.PDF
TSB 06-048 MIL Comes On With DTC P0116
Applies To: 2005–06 Odyssey – ALL
http://www.urvi.net/forumfiles/SB/A06-048.PDF
TSB 06-050 Drone or Moan When Driving at 2,100 RPM
http://www.urvi.net/forumfiles/SB/A06-050.PDF
TSB 06-068 Vehicle Pulling or Drifting
Applies To: ALL
http://www.urvi.net/forumfiles/SB/A06-068.PDF
TSB 06-072 TPMS Sensor Tool Usage
Applies To: 2007–08 Odyssey – ALL except Touring
http://www.urvi.net/forumfiles/SB/A06-072.PDF
TSB 06-085 Warranty Extension: Vehicle Warranty Mileage
Applies To: certain 2002 through 2006 Honda models
http://www.urvi.net/forumfiles/SB/A06-085.PDF
TSB 05-012 Moonroof Glass Weatherstrip Is Damaged
Applies To: 2005–07 Odyssey: ALL
http://www.urvi.net/forumfiles/SB/A05-012.PDF
TSB 05-032 Navigation System DVD Information and Inspection
Applies To: 2000–08 Odyssey
http://www.urvi.net/forumfiles/SB/A05-032.PDF
TSB 05-047 Honda Paint Codes, Exterior and Interior Color Code Locations
Applies To: 2006 Models – ALL
http://www.urvi.net/forumfiles/SB/A05-047.PDF
TSB 05-050 2006 Odyssey: PDI and New Model Information
Applies To: 2006 Odyssey – ALL
http://www.urvi.net/forumfiles/SB/A05-050.PDF
TSB 05-068 Product Improvement Campaign: Tire Valve Cap Replacement
Applies To: 2005 Odyssey Touring – ALL
2006 Odyssey Touring – From VIN 5FNRL388.6B000001 thru 5FNRL388.6B010540
2005 Pilot – From VIN 2HKYF18..5H500001 thru 2HKYF18..5H571501
2005 Pilot – From VIN 5FNYF18..5B000001 thru 5FNYF18..5B067307
2006 Ridgeline – From VIN 2HJYK16..6H500001 thru 2HJYK16..6H535591
http://www.urvi.net/forumfiles/SB/A05-068.PDF
TSB #08-084 Time on Display Changes Randomly
Applies To: 2005–09 Odyssey with Navigation – ALL
http://www.urvi.net/forumfiles/SB/A08-084.PDF
TSB #08-088 Service Manual Update: Poor AM or FM Reception
Applies To: ALL 2004–09 Models
http://www.urvi.net/forumfiles/SB/A08-088.PDF
TSB #08-078 Electrical Problems and B-CAN DTCs After Exposure to Water/Water Leaks
Applies To: 2005-2009 Odysseys
http://www.urvi.net/forumfiles/SB/A08-078.PDF
TSB # 09-042 Damaged Camshaft Position Sensor (CMP) Causes the MIL to Come On With DTC P0344
http://www.urvi.net/forumfiles/SB/A09-042.PDF
Power Sliding Door Stops at Half-Latch Position, Won’t Close
Currently Applies To: ’05–09 Odyssey
http://www.urvi.net/forumfiles/SN/A09060t.pdf
Rear Wheels Howl or Moan When Braking
http://www.urvi.net/forumfiles/SN/A09060o.pdf
TSB # 10-006 2005-06 Odyssey: MIL Comes On With DTC P0171
Applies To: 2005-06 Odyssey EX-L/EX-L Touring with J35A7 (VCM) engine – ALL
http://www.urvi.net/forumfiles/SB/A10-006.PDF
TSB # 09-051 Windshield Side Trim Retainer Is Loose or Broken
Applies To: 2005–10 Odyssey – ALL
http://www.urvi.net/forumfiles/SB/A09-051.PDF
TSB # 10-011 Service Manual Update: Power Window Goes Up and Reverses On Its Own,
Is Slow to Open and Close, or Squeals, Creaks, Clunks, or Clicks
VEHICLES AFFECTED: 2005–10 Odyssey – ALL
http://www.urvi.net/forumfiles/SB/A10-011.PDF
TSB 10-069 - Safety Recall: Master Cylinder May Be Leaking
2005 Odyssey
FromVIN 5FNRL3...5B000146
thru 5FNRL3...5B136928
FromVIN 5FNRL3...5B400014
thru 5FNRL3...5B425597
VIN 5FNRL3...5B503419
FromVIN 5FNRL4...5B129215
thru 5FNRL4...5B129244
2006 Odyssey
FromVIN 5FNRL3...6B000001
thru 5FNRL3...6B129961
FromVIN 5FNRL3...6B400001
thru 5FNRL3...6B463199
2007 Odyssey
FromVIN 5FNRL3...7B000201
thru 5FNRL3...7B068053
FromVIN 5FNRL3...7B400201
thru 5FNRL3...7B441549
http://www.urvi.net/forumfiles/SB/A10-069.PDF
TSB 10-076 - Steering Wheel Is Hard to Turn Quickly at Low Speeds
http://www.urvi.net/forumfiles/SB/A10-076.PDF
TSB 09-054 - Power Door Locks Continually Lock While Driving
Applies To: 2005–06 Odyssey – Touring models only
2007–09 Odyssey – ALL
http://www.urvi.net/forumfiles/SB/A09-054.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A09-054.PDF
TSB 12-029 - Warranty Extension: PCM Update for Lock-Up Clutch Function
Applies To: 2005–06 Odyssey EX-L and EX-L Touring – Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A12-029.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A12-029.PDF
TSB 14-015 - Safety Recall: Odyssey Fuel Smell or Leak
Applies To: 2005–10 Odyssey – ALL – Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A14-015.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A14-015/enu/A14-015.PDF
TSB 14-032 - Safety Recall: Odyssey Fuel Pump
Applies To: 2005-10 Odyssey - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A14-032.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A14-032/enu/A14-032.PDF
TSB 19-111 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram
Applies To: 2005-17 Odyssey
http://www.urvi.net/forumfiles/SB/A19-111.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-111/enu/A19-111.PDF
** SNIPPED **
Thanks so very much.........:D
** Edited to remove the full quoted post from NDNV so that we dont have to update the links when the URLs change yet again :(
Has anyone had the DVD player issue? Ours didn't load a disc today, so I suspect it's having this issue, but will see if it happens again before bringing it in. I was wondering if the remanuf. unit they are replacing it with has any new features (like mp3)? Fat chance, I know, but, figured I'd ask.
Where's the one about removing the plastic sheathing/covers on the rear AC lines to prevent them from rotting out?
Tom
New Dad New Van, are you a Honda mechanic? I'm looking for a particular part that is half price in the US. Would you know where I can get OEM Honda parts in Canada at the same US price?
The part no. is 18210-SHJ-A01 for a 2005 EX-L
Discussion Starter · #8 ·
No I'm not. I wish I could get OEM Honda parts at US prices but I am in the same boat as all other fellow Canadians. Best scenario is if you can cross border and purchase or know someone in the US. Borkerage, duty, GST/HST and shipping kill us here so works our the same at CDN prices.
New Dad New Van, well here's my story...
I'm looking at part # 18210-SHJ-A01 and is $366 CDN however it is $252US.
The good news is that I found Robertson Honda that has the part for $181 US. The bad news is that they don't deliver to Canada.
So my answer to that is we are going to Wildwood NJ next month and the local dealer there (Avalon) said that he can give it to me for $190 US and it's a 1 hr job.
We are so screwed in Canada price wise for parts it's unreal! Price gauging at it's best.
Onwards!!!!
Onwards!!!!
Check here:
Keenan Honda
www.keenanhondaparts.com (corrected)
Contact: [email protected]
By phone at (215)340-9016 or (888)345-5802.
We are located at:
854 North Easton Road
DOYLESTOWN, PA 18902
I buy from this Honda Dealer all the time and they do ship to Canada. They also sell stuff on eBay but it's almost the same price and is usually listed as Buy Now.
Discussion Starter · #11 ·
Most of the stuff I buy ships via Fed Ex ground or USPS Standard Service. You can choose shipping option on their website or call them for different shipping option if you need it faster. You can pay by Check, Money Order, Credit Card or Pay Pal. I bought about 6 things from them and never had any problems. Contact for Internet sales at Keenan Honda is Andy if you need to call them. Fed Ex charged me $29 brokerage fee for shipping a 2006 Odyssey hood deflector from US to Canada. Canada Border Services only charges the GST and PST only on car parts.
Wow I just found this thread and there are so many issues that may apply to my van that I may have to drop it off when I go on vacation so that they can tackle all of the issues (squeaking door, chirping noise from motor, SRS light, etc). Thanks for the info.
are you having these problems?
For some reason, the PDF links to the TSB's is no longer working, at least not for right now. I am mainly interested in the power steering pump recall. I seem to recall it was only for ones with a red lid on the filler cap ? Is that correct ?
Also, I assume it can be honored at any dealer at any time ? They do not try to ding you for any fees do they ?
Thanks.
06 Ody
07 Civic
A TSB is not a recall - it's simply a common enough issue that the manufacturer put together diagnosis and repair procedures for the dealers. If you are in warranty, then the repair (if you have the issue) is covered, otherwise, unless you can get them to goodwill the repair, it's on your dime.
Can anyone post the contents of A06-018.PDF (wheel bearing noise)?
Links to TSB seem broken and I couldn't find it anywhere else.
Thanks.
Discussion Starter · #19 ·
TSB and Service News links are now broken.
I need some tech help. I can get all TSBs in .PDF format. How do I post these here? Is there a web site I can post to and then reference this link?
In the meantime, send me an email address via PM and I will send the .PDF for the TSB on the wheel bearings.
Administrator
Updated all the TSB links. Not gotten around to Service News yet and I was not able to get ALL the PDF files. I got what I could and I might even have missed some.
1 - 20 of 33 Posts
Status
