Hello, after the car warms up I can distinctly smell light burning smell possibly rubber like. I'm not seeing any smoke. I jacked the car up and took a vid of a leak i noticed underneath the engine. Thoughts?
Holy smokes. Don't drive the car before it catches on fire.
Looks like transmission fluid, can't tell.
Get a degreaser and clean the grease, then look for the leak.
What does it look like from up top??? You can clearly see something has been running down the exhaust manifold for some time. Just based on what I see from your video, I would suspect a leaking valve cover gasket...How's you engine oil level....
I had a similar looking leak. Turned out to be the gasket around the oil filter housing. I had to remove the front wheel to find it but was super easy to change
I would guess it is the front Valve cover gasket , mine leaks from the back valve cover gasket and I get the same burning odor from oil hitting the exhaust pipe and also throws an occasional code when oil covers the Oxygen Sensor .
Most likely the front valve cover gasket. Mine is leaking too and looks almost identical. I have not yet addressed it because my valve adjustment is coming up in the next few weeks and will replace the gasket anyways. I only monitored it (no puddle under the van).
You can put some baby powder in the area to see where it is leaking from or you may use any sort of powder spray.
I'm in desperate need of help, my 2005 touring left me stranded yesterday morning. I went to start the van and nothing happened, the battery is good as I checked with an ohm meter and the batter is reading 12.65. I would turn the key and nothing would happen, lucky for me my old man had a...
My 05, 290k miles, is now showing some smoke. Especially when I did a 1000 lb trailer tow. Just 60 mile trip and watched for torque converter slippage and nursed the shift-er.
Does anyone have experience with using a higher wt oil. And or using Restore oil additive?
May just be the valve...
Just bought a 2010. The driver’s side door isn’t opening. It just beeps. Was going to order rollers and a sliding door motor. Just wondering if part number 72050-SHJ-A21 also unlocks and locks the door. At present, the door doesn’t auto lock/unlock or open. It just beeps. I tried removing fuse...
Hi guys,
I have an 08 EX-L with Navi & RES. My engine oil dries up pretty bad. I'm seriously considering doing an engine swap.
I would like to know if the 08 EX-L and 08 EX engines are interchangeable?
Can I use the engines like the LX/EX ones (without VCM)?
I just want something that is...
When I jack up the front (at the tow hook) the van makes a few popping sounds from both sides (louder on the passenger side). When I lower the van it makes the same loud popping. I think it has always made noises but they seem louder than before. I assumed it was just the suspension stretching...
