I am looking to change the pads on the rear brakes.. I have been reading that you just need a c clamp to compress.. is this the case.. does anyone have experience with the process.. I tried looking all over but could not find anything ..
So then, what IS "an additional step"? Anyone? ~smile~The rear rotor caliper is different than the front. You will need a tool to "rescrew" the piston in. Since it is connected to the parking brake, there is an additional step. Remember to crack the bleeder screw otherwise your ABS will be gone and you'll risk a leak.
