I put a new range sensor in and no change. All the drive lights are on and the D is blinking as usual. codes p0705, p0700, the 0705 says MOD $09, transmission range sensor A circuit (park / reverse/neutral/drive/low input). please help
What kind of scanner are you using? Does it show gear position when changed?
Also you used the OEM and no difference?
Any change after disconnecting the battery for few seconds and connecting it back?
It turns out that it was the wire harness that came off of the range sensor. It had somehow started rubbing on the boot of the axle and all the wires melted together and also ruined the boot. The harness was a 10 wire two connector easy fix.
