1 - 6 of 6 Posts
Hello everyone. So here is the issue:
When we go to start our van (to either cool it off in the van or heat it up before we get in), We open the sliding door to put our little one in and there is a constant beeping sound. It can only shut off if you flip the switch to the off position and then you would have to manually close the door or close the door and the beeping goes away. I doesn't do it with the van off. It's driving my wife crazy.
So if you have any thoughts or fixes about this, please let me know? Could it be a fuse? Debris? The doors close just fine though...I'm at a loss and not finding much online.
Thanks!
2006 Honda Odyssey (EX)
The door will beep if the van is detected to be in any gear besides P or N with the door open.
The van is in park though when this happens.
Sounds like the current gear is not being detected properly then.
A good start would be check for sliding door codes.
This video shows how you can do that by jumping some pins with foil in the driver's side footwell:
Reactions: kernel
Thanks!
But does the door open normally? So, it does not beep if you open the door when car is NOT started, but it does when you start the car?
Is it same behavior when the gear is in "N"? (or does the beeping goes away)
Yes it opens normally. It does not beep if I open the door when it's not started. Havent tried it when it's in N
1 - 6 of 6 Posts
