1 - 1 of 1 Posts
2007 Honda Odyssey EX-L RES
Hi,
Three very short questions:
1. Are these the correct parts for the oil drain plug and the matching washer:
- BOLT, DRAIN PLUG 14MM Honda P/N 90009-PY3-000
- WASHER, DRAIN PLUG, 14MM Honda P/N 94109-14000
2. How often need the AT fluid needs to be changed? I think the last one my was changed was in September 09 when the torque converter got replaced. Since than I drove about 20.000miles. I think the AT fluid needs to be replaced every 30.000miles, correct? Or better sooner than later?
Does the AT filter needs to be replaced as well?
3. A local Honda repair shop recommended to do a A/C service (checking for leaks, replacing the cooling gas or whatever it used, ...). Here in GY they recommend doing it every two years. Is it something I should do as well?
Regards,
Niels
1 - 1 of 1 Posts
