Original battery. Tested battery with 100 amp load and it seems fine. Resting voltage seems normal. Starts up very strong. Can leave the lights on for a while, start, no problems.
For some reason, the Navigation code needs to be entered regularly, the radio code as well, just not as often. Every once and a while we'll loose the memory to the power seats.
Every blue moon the sliding doors and rear tail gate won't open after the button is pushed.
Codes will pop up sometimes in the morning after a cold start AND sometimes in the afternoon while everything is warm after a quick trip into a store.
In the past I would have just replaced the battery, but the 2 times I've done that...it wasn't the battery.
Anyone have similar problems and what fixed it? Thanks.
