Need some help diagnosing my AC problem in my 2008 honda odyssey (110k miles). When we start the AC we get cold air for about 3min then it turns to hot humid air for about 5min then back to cold air for 3min.
I added some refrigerant, and the air got noticeably colder but still had the same problem. I didnt overcharge it.
Then I did some checking inside the engine. At the approx. 3min mark the clutch on the compressor disengages and so the compressor is off. I think that may be normal. Then the engine fan (the one on the drivers side) turns off for a few seconds, then turns back on for maybe 1min and 30sec, then stays off for about 3min 30sec. After this, both the compressor and the engine fan both turn back on and we get another 3min of cold air.
So in summary...
3min of cold air (compressor and engine fan on)
1.5min of warm are (compressor off, engine fan on)
3.5min of hot air (compressor and engine fan off)
then repeat...
I also checked the AC relay and that's not the issue. I did a spot check of the AC lines from the compressor back to the rear passenger tire area and i dont see any signs of a leak. I know that's not an official check for leaks but at least it's a start.
Anyone have any ideas? I've done a fair amount of work on my cars and am confident I can fix this myself if I know what the problem is. Appreciate your help! Thanks!
So in summary...
then repeat...
