1 - 20 of 43 Posts
Hello guys,
This past week my 08 Honda Odyssey touring threw the p3497 code. I've done some research and checked my oil levels which was low and topped it off for now, will do oil change soon (probably burning oil). I installed two new oil pressure switch front/rear reset the code and turned on the engine, received same result with week idel/weak engine and within 30 seconds the same code comes back on. I installed both old oil pressure sensor switch back as I thought those may not be the issue and went to sleep. This morning before going to work I turned on the engine and everything seemed fine, no rough idle/weak engine. It seems to be temperature caused? Will software update help? Any help is appreciated. I will be checking it again after work.
Discussion Starter #2
So I cleared the code and installed the two new oil pressure switch, drove the van for around 10 miles. P3497 came back on after the engine warmed up again. Any suggestions?
I've read some post and visited the vcm tuner site. Will disabling the vcm with vcm tuner help with the code?
It's a problem with valve pause system on bank 2 (front bank) so there's no reason to do anything with the rear bank at all. Installing a VCMTunerII might mask it but, personally, I'd get to the bottom of it before masking the issue with the VCMTuner.
If it were me, the first thing I'd do is change the oil, make sure you're using a good quality 5w-20 synthetic and an OEM Honda filter. Then I'd start chasing the problem if the code still returns.
Ok. Will do a full oil change tonight and follow up here.
Be sure and use an OEM filter. The OEM filter recommendation isn't because they are the best at this or that but because they are the known good and a baseline for starting a diagnosis. I have cured these valve pause codes before by just changing the oil and filter. Often I've found a cheap quick/jiffy lube filter on them. Those places buy filters for $0.50 and sell them for $5. They also use the cheapest bulk oil that can be bought.
Discussion Starter #7
Went to Honda dealer and got the 15400-RTA-003 oil filter and honda 5w-20 fully synthetic oil, changed the oil and added back 4.5qt. drove for around 7 miles and the same code came back on after the engine warmed up. No clue what to do next.
Discussion Starter #8 (Edited)
Could it be the variable valve timing solenoid or electrical wiring to the front oil pressure switch? Also could anyone explain why the code only pops when when the engine warms up? Is it the temperature that makes the vcm shut down the 3 cylinders?
245K 08 Odyssey - i have the same code. I have an oil leak around the VTEC selenoid. I dont know where the leak is from yet, (valve cover next to the selenoid or ...) but assumed the gaskets. I replaced both, then i got this message. I still have an oil leak. I will work on it this weekend.
Be sure to check your engine oil level frequently if you are still having this issue. Has to do with VCM. Follow John Clark's recommendations
I'm having almost the exact the same issue as lyndonvang, did you figure this out? I can drive around local streets as much as want without issue but when I get on the highway P3497 appears. If I let it cool down all is good.
Discussion Starter #13
Try this. There is a spool Valve in the rear of the engine, I've circled the connector in blue. Put 12v from the battery to it a couple of times and you will hear it clicks. I did this and it has been going good so far for around 800 miles. Hope this helps.
I had same problem on my 2008 ODY w 129,000.
There are several areas to investigate:
software update from dealer, loose/corroded ground wire strap (i cleaned ground wire on the very front of vehicle just under plastic shroud)
spark plugs, &
name brand full synthetic oil w OEM filter.
3497 has gone out and fully cleared from system.
I am getting the max muzzler today from maxud on the ODY forum. I aim to install it as a preventative measure as I don’t want the ECO light and VCM kicking in all the time.
Hope this helps!
Hi, I am experiencing same problem after vtec gasket replacement, how did you fix ? Appreciate your reply
My 2008 same thing replaced gaskets
Leak fixed
Week later light comes on. Code stating bad vtec Solenoid tried checking wires remove negative from battery light goes away few days later light comes back on. Will change oil 30 % and see
I have changed my oil now and will wait to see what happens
Also clean ground wire under front plastic.
I assumed I cause the problem because the keeper tab broke on the oil pressure switch
I made sure its on and connection is good used small tyraps to hold in place.
I am in the same situation. I replace leaking gaskets and a couple days later received. P3497. I have since done a complete oil change. No difference. Changed out the oil pressure switch on the spool valve, No change. I did find that typically I can drive low speed with no issue, eco light comes on and goes off. As soon as I am at a higher highway speed, Check engine light comes on and code P3497 shows back up. I cant help but to think that the issue was started when changing the gaskets. Possibly while moving the wire harness out of the way? Old wires getting brittle. I have not jumped the solenoid to verified correct functionality of it yet. I will post anything else I try and hopefully we can find an answer.
Torque specs, I went back after I found proper torque specs to make sure I did not warp the housing by torquing incorrectly. I found specs showing 72 inch lbs (actually it specified 6 ft lbs but my torque wrench that fits is in inch lbs) re-torqued and rest drive. When I get up to highway speed, light came back on and this time was accompanied with a flash (p304 misfire culture 4). I will swap solenoids and see what that has to show.
1 - 20 of 43 Posts
