1 - 13 of 13 Posts
Hi guys,
I used AUX input during our last trip and it seemed to work just fine (as usually). The next day I noticed that we are not getting any sound coming from the speakers. The head unit still has power and I can change the source input, radio channels, CD, AUX ... but there is no
sound. Also there is no error showing.
Tried to check fuses but everything seems to be fine (unless I am missing something).
I also tried to remove one of the rear speakers and installed a new one ... but that didn't help ... still no sound.
Any idea what to do (besides replacing the whole audio system)?
Thanks in advance.
Super Moderator
Check fuses 5 (10A) and 32 (10A) in the driver's under dash fuse/relay box
Discussion Starter #6
I disconnected the battery today and removed the stereo unit to see the model# (in case I need to buy another one). When I connected the radio again, I noticed that all my preset radio stations are still there.
Is there a way to reset the radio (again ... I don't see any error message displayed and it's not asking me to enter the code). Any help?
I am considering to buy used radio on eBay :( ... still cheaper then going to Honda dealer.
Super Moderator
Leave it disconnected for a while to reset. If you have a LX, the radio might not have the code to enter but since your presets stayed, you did not have the radio disconnected long enough.
Discussion Starter #8
I actually have DX (Canadian model) and you are probably right about the code. I will leave the radio disconnected as suggested until this afternoon ... will report the results. Thanks!
Discussion Starter #9
Radio was disconnected for more then 3 hours and after I put it back ... it worked for about 30 seconds and then it went back to silence???
Super Moderator
Something is toast inside.
Discussion Starter #11
Someone recommended following: "Sounds to me like you have a short in your wiring somewhere. Often times a short will cause your stereo to go into "protect" mode and cut power to all channels. To check for this, you could use a multimeter and test at the stereo wiring harness. Check the pairs or wires going to the 4 speakers for resistance. They should all be at least 2 ohms."
All I did was to remove rear speakers checked the radio and the sound is back. I connected back the same rear speakers and no problem .. all is working again. This all is very weird but my issue seems to be solved (at least for now).
Hope this can help somebody else. Thanks for the help.
Super Moderator
Interesting. I would check the wiring around the speakers to be sure but if this comes back, finding that short is going to take an act of God. :)
I did not know about this "protect" mode so I learnt something new today. :)
I know this is an old thread but hopefully this will help. I was having the same problem with my 2007 Odyssey Touring and searched all over this and other forums and found many other Honda owners having the exact same frustrating issue. Nothing worked. I replaced the fuses # 5 and #32 on the drivers side. No good. I installed a new radio. Did not fix it. Could not find any fuse labeled "Amp" or "Speakers" or similar anywhere. Finally I posted my own thread and an awesome person with the handle of "PostalTech" said to check fuse #5 in the small underhood fuse box. It was a 20 AMP fuse labeled "Premium" and it was blown. Also a 7.5 amp fuse for rear entertain was blown. Replaced both and sound restored. Your fuse boxes or labels may not be exactly the same as mine but I learned the lesson before I start chasing down more complicated problems to pull and check all fuses before moving on to more exotic solutions. Hope this helps others!
1 - 13 of 13 Posts
