Hey guys, I have a 2010 Oddyssey that had the common misfire problem, but was out of warranty. We paid out if pocket to have a piston re-ring completed. About 3 months later the engine shuts off randomly sitting idle in a parking lot. I sent it back to the same dealer, and they say the timing belt broke. The van has 113k miles. Timing belt was replaced at about 105k by someone else.
The dealer is not wanting to take any responsibility for what happened. I'm just now discovering they replaced the water pump when they did the ring job essentially replacing the 1 year old pump that was already there. I don't remember the pump being part of the scope of work, but they say it was. Why would they do the pump and not the timing belt? Either way they would have had to remove the belt to do the work.
They did a diagnostic and determined they "don't know" what caused the belt to break other than it was a "cheap aftermarket belt". It's a Mitsuboshi belt, which I've been told is actually the same belt and who makes the Honda oem belt. I now have bent valves and a van that doesn't turn on. Not really getting anything from the dealer in terms of a solution so far.
What would you do if you were me?
