Hi everyone. Been cruising the forums for a bit and learned alot to look for and have to give a props to everyone for the amazing content on the forum.
I just recently test drove an 11 with 125k miles, 205k Canadian. I asked to see the maintenance records and came across some of the common issues that have plauged this year from the vcm. New piston rings 1-3 have been replaced about 10k ago and new plugs 1-4 during the same service.
20k they replaced alternator, timing belt, water pump and tensioner belt. Had to replaced the v-tec spool valve, adjusted front and back valves and replaced all seals.
Finally had the left axel shaft replaced and ball joints front and rear done. 4 wheel alignment etc...
I'm asking if anyone would advise against this as it seems like its been a hefty money pit to the previous owner...
The stealership is asking 12,850 cdn.
