Hello to All,
I need an advice: my van started making noise described in TSB 13-016 - when parked and have AC running. There is also a mild leak from PS pump (replacing O-rings on intake and high pressure hose connections did not help). I have decided to buy an OEM remanufactured PS pump from on-line seller and replace it myself. Do I need to replace a front PS pump bracket as well, as described in the above mentioned service bulletin? Are the remanufactures PS pumps (06561-RV0-315RM ) coming with slots for 2 or 3 bolts? Does anyone have experience with this?
Thank you!
Thank you!
