Status
Not open for further replies.
1 - 20 of 55 Posts
Super Moderator
TSB 10-053 - 2011 Odyssey: PDI of the Navigation System
Applies To: 2011 Odyssey With Navigation – ALL
http://www.urvi.net/forumfiles/SB/A10-053.PDF
LinkDeny
TSB 10-057 - 2011 Odyssey: PDI Information
Applies To: 2011 Odyssey – ALL
http://www.urvi.net/forumfiles/SB/A10-057.PDF
LinkDeny
TSB 10-066 - Dashboard Center Panel Visor Is Loose or Has a Gap
Applies To: 2011 Odyssey – From VIN 5FNRL5H..BB000001 thru 5FNRL5H..BB003748
http://www.urvi.net/forumfiles/SB/A10-066.PDF
LinkDeny
TSB 10-067 - Rear Entertainment System Displays ”Parental Error” on Audio Display
Applies To: 2011 Odyssey EX-L with RES – ALL
http://www.urvi.net/forumfiles/SB/A10-067.PDF
LinkDeny
TSB 10-078 - Sliding Door Outer Trim Is Warped
Applies To: 2011 Odyssey – From VIN 5FNRL5H..BB000001 thru 5FNRL5H..BB005502
http://www.urvi.net/forumfiles/SB/A10-078.PDF
LinkDeny
TSB 11-002 - Driver’s Side Sliding Door Does Not Unlock or Open
http://www.urvi.net/forumfiles/SB/A11-002.PDF
LinkDeny
TSB 11-004 - Front Bumper Paint Is Peeling at the Front Fender Gap
http://www.urvi.net/forumfiles/SB/A11-004.PDF
LinkDeny
TSB 11-009 - Front Door Window Glass Is Separated From the Regulator
Applies To: See VEHICLES AFFECTED
VEHICLES AFFECTED
2011 Odyssey
Replace both front door windows:
From VIN 5FNRL5...BB014762 thru 5FNRL5...BB016603
Replace only the right front door window:
From VIN 5FNRL5...BB016604 thru 5FNRL5...BB017563
http://www.urvi.net/forumfiles/SB/A11-009.PDF
LinkDeny
TSB 11-017 - Safety Recall: Frozen Windshield Wipers Do Not Work
Applies To: 2011 Odyssey LX – From VIN 5FNRL5H2.BB006767 thru 5FNRL5H2.BB034357
2011 Odyssey EX – From VIN 5FNRL5H4.BB001001 thru 5FNRL5H4.BB034405
2011 Odyssey EX-L – From VIN 5FNRL5H6.BB001061 thru 5FNRL5H6.BB034420
2011 Odyssey Touring – From VIN 5FNRL5H9.BB001031 thru 5FNRL5H9.BB034297
http://www.urvi.net/forumfiles/SB/A11-017.PDF
LinkDeny
TSB 10-081 - Product Update: Audio Unit Software Update for Security Code, Clock Reset, HFL, and Other Listed Issues
Applies To: 2011 Odyssey LX, EX, EX-L, EX-L with RES without Navi – See VEHICLES AFFECTED
VEHICLES AFFECTED
2011 Odyssey LX
From VIN 5FNRL5H2.BB006767 thru 5FNRL5H2.BB043409
2011 Odyssey EX
From VIN 5FNRL5H4.BB001001 thru 5FNRL5H4.BB044751
2011 Odyssey EX-L
From VIN 5FNRL5H6.BB001061 thru 5FNRL5H6.BB044506
2011 Odysey EX-L with RES
From VIN 5FNRL5H6.BB001061 thru 5FNRL5H6.BB015256
http://www.urvi.net/forumfiles/SB/A10-081.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A10-081.PDF
TSB 11-018 - Safety Recall: Front Passenger’s Door Window Glass Is Separated From the Regulator
(Replaces 11-009, Front Door Window Glass Is Separated From the Regulator, dated March 22, 2011)
Applies To: 2011 Odyssey – 5FNRL5...BB016604 thru 5FNRL5...BB017563
http://www.urvi.net/forumfiles/SB/A11-018.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A11-018.PDF
TSB 11-019 - Safety Recall: Driver’s and Front Passenger’s Door Window Glass Are Separated From the Regulators
Applies To: 2011 Odyssey – 5FNRL5...BB014762 thru 5FNRL5...BB016603
http://www.urvi.net/forumfiles/SB/A11-019.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A11-019.PDF
TSB 11-022 - Navigation Display Intermittently Remains Blank After Starting
Applies To: 2011 Odyssey with Navigation – From VIN 5FNRL5H..BB000001 thru 5FNRL5H..BB025028
http://www.urvi.net/forumfiles/SB/A11-022.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A11-022.PDF
TSB 11-033 - Engine Oil Consumption; MIL May Be On With DTC P3400 and/or P3497
Applies To: 2011 Odyssey – From VIN 5FNRL5H..BB000001 thru 5FNRL5H..BB061689
http://www.urvi.net/forumfiles/SB/A11-033.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A11-033.PDF
TSB 11-038 - Popping, Knocking, or Creaking in the Front While Turning at Low Speeds
2012 Odyssey – From VIN 5FNRL5H..CB000001 thru 5FNRL5H..CB088499
http://www.urvi.net/forumfiles/SB/A11-038.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A11-038.PDF
TSB 11-067 - CHECK FUEL CAP Message Comes On Repeatedly Without a DTC
Applies To: 2011–12 Odyssey – ALL
2013 Odyssey – From VIN 5FNRL5H..DB000001 thru 5FNRL5H..DB021570
http://www.urvi.net/forumfiles/SB/A11-067.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A11-067.PDF
TSB 11-073 - Product Update: MID Shows BATTERY CHARGE LOW or bATT LOW
Applies To: 2011 Odyssey – Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A11-073.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A11-073.PDF
TSB 11-076 - Audio Display Stays On With Ignition Switch In LOCK (0)
Applies To: 2011 Odyssey EX-L Without Navigation – ALL
http://www.urvi.net/forumfiles/SB/A11-076.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A11-076.PDF
TSB 08-017 - Engine Knocks or Ticks at Idle
Applies To: 2011–12 Odyssey EX-L/Touring – From VIN 5FNRL5H..CB000001 thru 5FNRL5H..CB021569
http://www.urvi.net/forumfiles/SB/A08-017.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A08-017.PDF
TSB 12-021 - Engine or Wind Noise From the Left Front Quarter Glass
Applies To: 2011 Odyssey – From VIN 5FNRL5H..BB000001 thru 5FNRL5H..BB070337
http://www.urvi.net/forumfiles/SB/A12-021.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A12-021.PDF
TSB 11-070 - Product Update: CD or DVD (RES) Restarts When the Ignition Switch Is Turned OFF and ON
Applies To: 2011–12 Odyssey with Navigation – Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A11-070.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A11-070.PDF
TSB 12-030 - Wind Noise From the Front Door Glass
http://www.urvi.net/forumfiles/SB/A12-030.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A12-030.PDF
TSB 12-035 - XM Radio Intermittently Loses Sound
2012 Odyssey – From VIN 5FNRL5...CB000001 thru 5FNRL5...CB075600
http://www.urvi.net/forumfiles/SB/A12-035.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A12-035/enu/A12-035.PDF
TSB 10-060 - 2008–11 Odyssey: MIL Comes On With DTC P0300 Thru P0304
Applies To: 2008–10 Odyssey EX-L, Touring – ALL
http://www.urvi.net/forumfiles/SB/A10-060.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A10-060.PDF
TSB 12-064 - Surge, Hesitation, or Judder on Upshifts
This bulletin is replaced by 16-046, Product Update: 2011–12 Odyssey Software Update for Lock-up Clutch Function
http://www.urvi.net/forumfiles/SB/A12-064.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A12-064/enu/A12-064.PDF
TSB 13-002 - Warranty Extension: 2011–12 Odyssey Tailgate Paint Finish
Applies To: 2011–12 Odyssey – Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A13-002.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A13-002.PDF
TSB 13-008 - Safety Recall: Driver’s Airbag Missing Rivets
Applies To: 2011–13 Odyssey – Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A13-008.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A13-008.PDF
TSB 13-031 - MIL Comes On With DTC P3400 and/or P3497
Applies To: 2008–11 Odyssey EX-L and Touring - ALL
2012 Odyssey - From VIN 5FNRL5...CB000001 thru 5FNLR5...CB138229
http://www.urvi.net/forumfiles/SB/A13-031.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A13-031.PDF
TSB 13-033 - Speakers Pop
Applies To: 2011–13 Odyssey – ALL with Navigation
http://www.urvi.net/forumfiles/SB/A13-033.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A13-033/enu/A13-033.PDF
TSB 13-081 - Warranty Extension: MIL Comes On With DTCs P0301 Through P0304
Applies To: 2011-13 Odyssey – Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A13-081.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A13-081/enu/A13-081.PDF
TSB 13-100 - Keyless Remote Cracks Or Breaks
Applies To: 2011–13 Odyssey – EX, EX-L, and Touring
http://www.urvi.net/forumfiles/SB/A13-100.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A13-100.PDF
TSB 09-099 - Keyless Remote Works Intermittently Or Not At All
Applies To: 2011 Odyssey – All (except LX)
2012 Odyssey – All (except LX)
2013 Odyssey – (except LX)
From VIN 5FNRL5...DB000001 thru 5FNRL5...DB078264
http://www.urvi.net/forumfiles/SB/A09-099.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A09-099.PDF
TSB 13-016 - Power Steering Noise With the A/C Compressor On
2014 Odyssey – From VIN 5FNRL5...EB000001 thru 5FNRL5...EB015712
http://www.urvi.net/forumfiles/SB/A13-016.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A13-016.PDF
TSB 14-009 - Driver’s Seat Heater Shuts Off After Turning On
Applies To: 2011-13 Odyssey - EX-L and Touring – ALL
http://www.urvi.net/forumfiles/SB/A14-009.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A14-009/enu/A14-009.PDF
TSB 14-028 - Special Tools for Camera and Radar Aiming
Applies To: 2011-14 Odyssey - EX-L, Touring Elite
http://www.urvi.net/forumfiles/SB/A14-028.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A14-028/enu/A14-028.PDF
TSB 14-066 - Clunk or Squeak From the Rear Suspension/Rear Lower Spring Seat Deterioration
Applies To: 2011-14 Odyssey - ALL
http://www.urvi.net/forumfiles/SB/A14-066.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A14-066/enu/A14-066.PDF
TSB 14-076 - Rattle From the Tailgate Area On Rough Roads or Going Over Bumps
Applies To: 2011-15 Odyssey - All with power tailgate - ALL
http://www.urvi.net/forumfiles/SB/A14-076.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A14-076/enu/A14-076.PDF
TSB 14-073 - New Warranty Instructions for TPMS-Related Repairs
Applies To: 2007-15 Odyssey - ALL
http://www.urvi.net/forumfiles/SB/A14-073.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A14-073/enu/A14-073.PDF
TSB 14-074 - Third Row Seat Cup Holder Gets Warm
Applies To: 2011-15 Odyssey - ALL
http://www.urvi.net/forumfiles/SB/A14-074.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A14-074/enu/A14-074.PDF
TSB 15-032 - Roof Rack Rattles
Applies To: 2011–15 Odyssey - ALL
http://www.urvi.net/forumfiles/SB/A15-032.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A15-032/enu/A15-032.PDF
TSB 15-064 - Door Sash Outer Trim Is Warped
http://www.urvi.net/forumfiles/SB/A15-064.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A15-064/enu/A15-064.PDF
TSB 13-095 - 2011–14 Odyssey: MIL Comes On with DTC P0404
Applies To: 2011-13 Odyssey - ALL - ALL
2014 Odyssey - ALL - From VIN 5FNRL5H..EB000001 thru 5FNRL5H..EB029152
http://www.urvi.net/forumfiles/SB/A13-095.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A13-095/enu/A13-095.PDF
TSB 16-005 - Multiple Indicators Are On With DTC 81-1 and/or DTC 61-1
Applies To: 2011-14 Odyssey - ALL - ALL
2015 Odyssey - ALL - From VIN 5FNRL5...FB000001 thru 5FNRL5...FB039984
http://www.urvi.net/forumfiles/SB/A16-005.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A16-005/enu/A16-005.PDF
TSB 16-003 - Product Update: 2011–14 Odyssey Vehicle Certification Label
Applies To: 2011-14 Odyssey - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A16-003.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A16-003/enu/A16-003.PDF
TSB 16-046 - Product Update: 2011–12 Odyssey Software Update for Lock-up Clutch Function
Applies To: 2011-12 Odyssey - Touring and Touring Elite - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A16-046.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A16-046/enu/A16-046.PDF
TSB 16-052 - Warranty Extension: 2011–12 Odyssey Torque Converter
http://www.urvi.net/forumfiles/SB/A16-052.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A16-052/enu/A16-052.PDF
TSB 16-063 - Tailgate Will Not Open from the Outside Handle in Cold Weather
Applies To: 2011-2017 Odyssey - ALL - ALL
http://www.urvi.net/forumfiles/SB/A16-063.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A16-063/enu/A16-063.PDF
TSB 16-108 - Safety Recall: 2011-16 Odyssey Second Row (Both Outer) Seats
Applies To: 2011-16 Odyssey - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A16-108.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A16-108/enu/A16-108.PDF
TSB 17-031 - Second-Row Center Seat Cup Holder Is Loose or Broken
Applies To: 2011-17 Odyssey - ALL - ALL
http://www.urvi.net/forumfiles/SB/A17-031.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A17-031/enu/A17-031.PDF
TSB 17-097 - Safety Recall: Outer Second Row Seats Tip During Braking
This bulletin is replaced by S/B 18-021, Safety Recall: Second Row Outer Seat Striker Bracket (Seat Tipping)
http://www.urvi.net/forumfiles/SB/A17-097.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A17-097/enu/A17-097.PDF
TSB 18-021 - Safety Recall: Second Row Outer Seat Striker Bracket (Seat Tipping)
Applies To: 2011-17 Odyssey - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A18-021.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A18-021/enu/A18-021.PDF
TSB 19-056 - Warranty Extension: Taffeta White Paint (6 Months)
Applies To: 2011-12 Odyssey - All vehicles painted Taffeta White NH-578 - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A19-056.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-056/enu/A19-056.PDF
TSB 19-111 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram
Applies To: 2005-17 Odyssey
http://www.urvi.net/forumfiles/SB/A19-111.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-111/enu/A19-111.PDF
TSB 20-023 - Front Rocker Arm Oil Control Valve Leaks
Applies To: 2008-10 Odyssey - EX-L and higher - ALL
http://www.urvi.net/forumfiles/SB/A20-023.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A20-023/enu/A20-023.PDF
Is there a reason we can't view the links?
It says i'm not authorized.
Super Moderator
Administrator
Thanks to the both of you EE and NDNV. Swapped out the links as folks are still having trouble with the workaround.
Super Moderator
The link gets shortened by the forum, causing you to receive the error message. Here is the real link, minus the http: portion.
//estore.honda.com/accesssory-installation-instructions/vehicle-chooser.asp
It looks like you need to do this link daily to continue to have access.
Administrator
Sorry for the long delay. Posts have been merged to update the top OP. Links have been updated.
EE4life and NDNV, you both have a PM.
dvpatel, This is a great resource. Thanks. Tom
The 2011 model is sure following the consistent lengthy list of TSBs and recalls for a first generation model year...:(
im not sure if im blind right now, but since i didn't see it up there i just wanted to ask.
I went to my dealership today for my flat spotted tires and they noticed that they had
an upgrade for the pcm on our ody elite. Do you have any information on this?
thanks!
I remember it as PCM and something else related to tranny. They told me they had two
updates available, which i got them done yesterday. You should give your dealership a
call because they told me honda just came out with it recently.
Super Moderator
Discussion Starter · #17 ·
richysh and hxpz1d1:
Did either of you obtain more info from your dealer on any updates you mentioned that were applied to your Odys? I was not aware of anything.
Thank you for posting A11-038. My dealer kept saying they cannot find the creaking sound. Today, I called and scheduled an appointment for them to do this service bulletin. Hopefully with the bulletin in hand, they would not argue about not hearing it (again).
BTW, shouldn't this bulletin be pinned to the first post?
so when can we schedule to get these things fixed?
I'm experiencing several of them.
Is it something i can call the dealer for, and they'll do them?
I just discovered that for Canadians there's no way of knowing if there are any TSB's (Technical Service Bulletins) issued. This is "proprietary" information and is shared as "guidance" for Canadian dealers, and isn't shared with the public.
The color of the HONDA logo on the top left of the bulletin indicates if TSB is US (blue) or Canadian (red).
RE: Recalls: you can call Customer Relations 1-888-946-6329 with a VIN to ask for recall information. As of 10/16/2011 there is only 1 recall on the Windshield Wipers Rotors (?) issue that affects some VINs.
1 - 20 of 55 Posts
Status
