Hi, I was wondering if anyone had a similar situation; for three mornings in a row, the NAVI and the radio/DVD system on my van would not power on when the ignition is started. The "system" would remain "powerless" for the most part while the van is being driven, then at the brink of an eye, power is restored. This also occurs when the van is turned off, idled for a few minutes, and turned on again. Now, the problem with the power source happens in the morning (at cold start) and in the evening when I go pick up the car from the parking lot after work. Could this be a problem with the fuse? the wiring? battery connection?
Thank you!
Thank you!
