2011 Odyssey Touring shocks/struts
2175 Views 25 Replies 10 Participants Last post by  tripletrip
I need to replace shocks/struts on my 2011 Odyssey with about 120K miles. From reading the forums, it appears that KYB is the preferred non OEM brand, however they don't seem to offer strut assemblies for this vehicle. I talked to 3 different installers and I was advised that it would be cheaper to purchase a complete assembly, but the only ones I found on line are Monroe and TRQ plus some other brands I have never heard of (FCS ?).
So, here is the question: should I just get the KYB excel Gs (from rock auto) and just deal with the higher cost of the front installation ? I do need new boots for the front, but I am unsure if I also need to buy the strut mounts.
Also, for "warranty reasons", the installer's quoted prices for these items is 2.5X what i can get them from Rock Auto, Amazon or even TIreRack. Is this warranty worth it ? if one of these goes bad, I just replace it and I am still ahead.
I wish I had access to a lift so I could do this myself, it definitely does not look too hard to do.
Thanks !
1 - 20 of 26 Posts
Thanks !
A jack and two jack stands will get it done... (well, and some tools)
It is sad to me that a shop would charge a significant amount more for about 10 minutes of labor, but here we are. They should want happy customers who use good quality parts (KYB over Monroe, TRQ, FCS, etc.).
Either way, you will still need an alignment when done.
-Charlie
-Charlie
Thanks, Charlie ! I was quoted $640 for labor for front and rear + alignment.
I have plenty of tools, jack and jackstands and will attempt the rear shocks first. Need only to procure torque wrench.
What is the likelihood of not being able to reuse the existing bolts ? this car is my daily driver, so I cannot take the risk that it as to sit waiting for parts...
The front end intimidates me at this point.
Depends on rust belt or not... I did my rear shocks (leaking) recently with 0 broken bolts, etc. 2016 with ~70k miles, California driven.
-Charlie
-Charlie
I am in the San Jose area, so I guess I am safe ....
Get yourself some PB blaster and shoot the hardware a week in advance and then a couple times that week prior too.
If you really want the best penetrating oil order up some aerokroil or mouse milk. I use mouse milk and only mouse milk. IMO it's at least 10x better than PB. Napa usually has Aerokroil. But its not likey you'll break anything at that age if it's been in cali imost of its life.
Reactions: 1
hows the odor on mouse milk?
aerokroil really stinks to high hell.
AvE on youtube shoots it to shit on how effective it is.
I have a can and find its creeping ability to be better than most, but the formulation is not best in class.
creeping is half the work with a rust penetrate.
project farm proves brake fluid is still the best.
others have shown ATF and acetone to be quite effective.
I just want something that works and doesn't need you to clear out of the garage after using it.
FWIW I recently picked up a can of Lucas penetrating oil and am very happy with it. It works at least as well as PB Blaster but no smell whatsoever. I can't say how it performs in comparison to aerokroil or mouse milk but the odorless formulation moves it to the top of my list.
Reactions: 1
Since your vehicle is also your daily, I would attack the suspension in stages. Rears on one day, then the front when you have more time.
To help minimize your time spent raising and lowering, my suggestion is to use your jack to raise the rear of the vehicle from the central jackpoint (a bit past the hitch, or where a hitch would be). You can place jackstands at the rear, side jack points. This frees up your jack to help align the rear spring seat when you need to position the bolt back through.
For the front, just be mindful of the axle sliding out when you remove the suspension. It's not hard to position back in place.
I agree, Kroil really smells strong, which is one of the reasons I don't use it much anymore. Mouse milk has a solvent smell, but it goes away quickly. Kroil seems to linger in your garage for weeks.
I haven't tried Lucas. I was an aircraft mechanic for 15yr. Out of all the penetrating oils I've used my favorite is by far Mouse Milk. Heck, I used a ton of it last year on my 05 pilot when I replaced the exhaust system. Even the cats that had been on since 05, the nuts came right off after I had let them soak. What I like about Mouse Milk is the solvent evaporates, but it seems to leave the fastener wet much longer. It also spreads across the metal significantly further than kroil or PB, which seems to match its penetrating properties. I've used it on cars obviously but even on jet engine fuel nozzle fasteners that are notoriously seized due to high temps it makes them a breeze. Usually with Kroil we had to soak the hardware the night before. Let the plane fly then the next evening we would soak them again at the beginning of our shift then after a few hours tackle them. Mouse milk fasteners were always significantly easier to break free. Same with exhaust work on cars. Mouse milk just seems to really work its way fully down between the fastener, threads and even where the clamping force of the nut is being applied against the mating part.
See less See more
Reactions: 1
^^^^^ Previous owner of mine did his. He ruined the CV axle by not paying attention. Boot slipped off and all he had to do was slip it back on. The Ody is the first vehicle in many years that's burned me by not replacing the output shaft seal too with the CV. I almost never have too. But this one leaked while driving. Not while sitting or in the garage spinning the wheels with it running in the air. Also, if you have a TE you need to disconnect the linkage on the control arm for the suspension position sensor.
On the rear, there is a jack point in the middle of the rear subframe for lifting. The front jack point is much closer to the front of the vehicle, just behind the radiator core support on the front subframe..
Central lift points:
Jack stand or 2-post lift points:
-Charlie
See less See more
2
Reactions: 2
Thanks to all for the very useful tips!!!
  • I have mouse milk on order and will apply over time to let it soak in. I am in no hurry
  • I plan on doing the rears one day and see how I do, then tackle the fronts. Wheelworks is 2mi. down the street for an alignment job after that.
  • Jack stands on the rear points and keep the jack free for the spring compression
  • CV joints and boots are fairly fresh, since they were replaced not long ago, but I will pay attention as recommended.
Best regards,
Stefano
Reactions: 1
You are in California... you'll be fine even without it for this work.
-Charlie
-Charlie
I forgot about the front one. That one makes life much easier, unless you are me. I have to roll the front of the minivan up on ramps, then go to jack the van up on that central point you indicated. I can't get enough space to operate the jack since the van is lowered and has a front lip spoiler. 😂
I keep a few old emergency scissor jacks to lift that first couple inches before I can get the regular jack under the front on my lowered cars... And built a set of low ramps (solid wood) to set them back down on when done (hard to get up safely with manual trans). Its never easy to modify a vehicle. ;)
-Charlie
  • Love
Reactions: 1
-Charlie
Update on the shocks/struts: I successfully replaced the shocks and everything went as expected. I used the Honda jack because I could use my Makita drill as the motive force. I do have jack stands so everything was nice and safe. I am going to chicken out for the front struts and ask a trusted mechanic to do it, since he can also do the alignment in his shop and I just saw him at work on my wife's car (tire replacement, 4th flat in 1 year ).
Thanks for all the help!
  • Love
Reactions: 1
Kudos for doing your shocks!
Is there a lot of construction or potholes for your wife's commute?
Did you end up getting the KYB shocks?
I got the KYB Excel G's. They feel a little firmer than the OEM, but I will know more once the fronts are done.
My mechanic is disappointed that I did not buy Monroe, which is what he is pushing...
As for all the flats, my neighbor has been remodeling his house for 2 years, and I am sure that accounts for at least 3/4 flats.
Reactions: 1
1 - 20 of 26 Posts
