Status
Not open for further replies.
1 - 20 of 39 Posts
Super Moderator
TSB 10-053 - 2011–12 Odyssey: PDI of the Navigation System
Applies To: 2011–12 Odyssey With Navigation – ALL
http://www.urvi.net/forumfiles/SB/A10-053.PDF
LinkDeny
TSB 11-056 - 2012 Odyssey: PDI Information
Applies To: 2012 Odyssey – ALL
http://www.urvi.net/forumfiles/SB/A11-056.PDF
LinkDeny
TSB 11-070 - Product Update: CD or DVD (RES) Restarts When the Ignition Switch Is Turned OFF and ON
Applies To: 2012 Odyssey with Navigation – Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A11-070.PDF
LinkDeny
TSB 08-017 - Engine Knocks or Ticks at Idle
Applies To: 2011–12 Odyssey EX-L/Touring – From VIN 5FNRL5H..CB000001 thru 5FNRL5H..CB021569
http://www.urvi.net/forumfiles/SB/A08-017.PDF
LinkDeny
TSB 11-038 - Popping, Knocking, or Creaking in the Front While Turning at Low Speeds
Applies To: 2011 Odyssey – ALL
2012 Odyssey – From VIN 5FNRL5H..CB000001 thru 5FNRL5H..CB088499
http://www.urvi.net/forumfiles/SB/A11-038.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A11-038.PDF
Applies To: 2011–12 Odyssey with Navigation – Check the iN VIN status for eligibility
LinkDeny
TSB 12-030 - Wind Noise From the Front Door Glass
Applies To: 2011–12 Odyssey – ALL
http://www.urvi.net/forumfiles/SB/A12-030.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A12-030.PDF
TSB 12-035 - XM Radio Intermittently Loses Sound
2012 Odyssey – From VIN 5FNRL5...CB000001 thru 5FNRL5...CB075600
http://www.urvi.net/forumfiles/SB/A12-035.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A12-035/enu/A12-035.PDF
TSB 12-064 - Surge, Hesitation, or Judder on Upshifts
This bulletin is replaced by 16-046, Product Update: 2011–12 Odyssey Software Update for Lock-up Clutch Function
http://www.urvi.net/forumfiles/SB/A12-064.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A12-064/enu/A12-064.PDF
TSB 13-002 - Warranty Extension: 2011–12 Odyssey Tailgate Paint Finish
Applies To: 2011–12 Odyssey – Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A13-002.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A13-002.PDF
TSB 13-008 - Safety Recall: Driver’s Airbag Missing Rivets
Applies To: 2011–13 Odyssey – Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A13-008.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A13-008.PDF
TSB 11-067 - CHECK FUEL CAP Message Comes On Repeatedly Without a DTC
2013 Odyssey – From VIN 5FNRL5H..DB000001 thru 5FNRL5H..DB021570
http://www.urvi.net/forumfiles/SB/A11-067.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A11-067.PDF
TSB 13-036 - Safety Recall: 2012-13 Odyssey Shift Interlock Stopper
Applies To: 2012–13 Odyssey – Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A13-036.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A13-036.PDF
TSB 13-031 - MIL Comes On With DTC P3400 and/or P3497
Applies To: 2008–11 Odyssey EX-L and Touring - ALL
2012 Odyssey - From VIN 5FNRL5...CB000001 thru 5FNLR5...CB138229
http://www.urvi.net/forumfiles/SB/A13-031.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A13-031.PDF
TSB 13-033 - Speakers Pop
Applies To: 2011–13 Odyssey – ALL with Navigation
http://www.urvi.net/forumfiles/SB/A13-033.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A13-033/enu/A13-033.PDF
TSB 13-081 - Warranty Extension: MIL Comes On With DTCs P0301 Through P0304
Applies To: 2011-13 Odyssey – Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A13-081.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A13-081/enu/A13-081.PDF
TSB 13-100 - Keyless Remote Cracks Or Breaks
Applies To: 2011–13 Odyssey – EX, EX-L, and Touring
http://www.urvi.net/forumfiles/SB/A13-100.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A13-100.PDF
TSB 09-099 - Keyless Remote Works Intermittently Or Not At All
Applies To: 2011 Odyssey – All (except LX)
2012 Odyssey – All (except LX)
2013 Odyssey – (except LX)
From VIN 5FNRL5...DB000001 thru 5FNRL5...DB078264
http://www.urvi.net/forumfiles/SB/A09-099.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A09-099.PDF
TSB 13-016 - Power Steering Noise With the A/C Compressor On
2014 Odyssey – From VIN 5FNRL5...EB000001 thru 5FNRL5...EB015712
http://www.urvi.net/forumfiles/SB/A13-016.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A13-016.PDF
TSB 14-009 - Driver’s Seat Heater Shuts Off After Turning On
Applies To: 2011-13 Odyssey - EX-L and Touring – ALL
http://www.urvi.net/forumfiles/SB/A14-009.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A14-009/enu/A14-009.PDF
TSB 14-010 - MIL Comes On With DTC P0455 and/or P0456
2013 Odyssey – From VIN 5FNRL5...DB000001 thru 5FNRL5...DB011685
http://www.urvi.net/forumfiles/SB/A14-010.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A14-010/enu/A14-010.PDF
TSB 14-016 - Pop or Clunk From Front End When Driving Over Bumps In Cold Weather
Applies To: 2012 Odyssey – From VIN 5FNRL5H..CB088500 thru 5FNRL5H..CB999999
2013 Odyssey – ALL
2014 Odyssey - From VIN 5FNRL5H..EB000001 thru 5FNRL5H..EB060508
http://www.urvi.net/forumfiles/SB/A14-016.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A14-016/enu/A14-016.PDF
TSB 14-028 - Special Tools for Camera and Radar Aiming
Applies To: 2011-14 Odyssey - EX-L, Touring Elite
http://www.urvi.net/forumfiles/SB/A14-028.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A14-028/enu/A14-028.PDF
TSB 14-066 - Clunk or Squeak From the Rear Suspension/Rear Lower Spring Seat Deterioration
Applies To: 2011-14 Odyssey - ALL
http://www.urvi.net/forumfiles/SB/A14-066.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A14-066/enu/A14-066.PDF
TSB 14-076 - Rattle From the Tailgate Area On Rough Roads or Going Over Bumps
Applies To: 2011-15 Odyssey - All with power tailgate - ALL
http://www.urvi.net/forumfiles/SB/A14-076.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A14-076/enu/A14-076.PDF
TSB 14-073 - New Warranty Instructions for TPMS-Related Repairs
Applies To: 2007-15 Odyssey - ALL
http://www.urvi.net/forumfiles/SB/A14-073.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A14-073/enu/A14-073.PDF
TSB 14-074 - Third Row Seat Cup Holder Gets Warm
Applies To: 2011-15 Odyssey - ALL
http://www.urvi.net/forumfiles/SB/A14-074.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A14-074/enu/A14-074.PDF
TSB 15-032 - Roof Rack Rattles
Applies To: 2011–15 Odyssey - ALL
http://www.urvi.net/forumfiles/SB/A15-032.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A15-032/enu/A15-032.PDF
TSB 15-064 - Door Sash Outer Trim Is Warped
http://www.urvi.net/forumfiles/SB/A15-064.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A15-064/enu/A15-064.PDF
TSB 13-095 - 2011–14 Odyssey: MIL Comes On with DTC P0404
Applies To: 2011-13 Odyssey - ALL - ALL
2014 Odyssey - ALL - From VIN 5FNRL5H..EB000001 thru 5FNRL5H..EB029152
http://www.urvi.net/forumfiles/SB/A13-095.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A13-095/enu/A13-095.PDF
TSB 16-005 - Multiple Indicators Are On With DTC 81-1 and/or DTC 61-1
Applies To: 2011-14 Odyssey - ALL - ALL
2015 Odyssey - ALL - From VIN 5FNRL5...FB000001 thru 5FNRL5...FB039984
http://www.urvi.net/forumfiles/SB/A16-005.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A16-005/enu/A16-005.PDF
TSB 16-003 - Product Update: 2011–14 Odyssey Vehicle Certification Label
Applies To: 2011-14 Odyssey - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A16-003.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A16-003/enu/A16-003.PDF
TSB 16-046 - Product Update: 2011–12 Odyssey Software Update for Lock-up Clutch Function
Applies To: 2011-12 Odyssey - Touring and Touring Elite - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A16-046.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A16-046/enu/A16-046.PDF
TSB 16-052 - Warranty Extension: 2011–12 Odyssey Torque Converter
http://www.urvi.net/forumfiles/SB/A16-052.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A16-052/enu/A16-052.PDF
TSB 16-060 - Judder from the Torque Converter Lock-Up Clutch
This bulletin is replaced by 17-052, 2012-13 Odyssey: Judder from the Torque Converter Lock-Up Clutch (Snapshot Required), and 18-017, 2012-13 Odyssey: Judder from the Torque Converter Lock-Up Clutch After Software Update (Snapshot Required)
http://www.urvi.net/forumfiles/SB/A16-060.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A16-060/enu/A16-060.PDF
TSB 16-063 - Tailgate Will Not Open from the Outside Handle in Cold Weather
Applies To: 2011-2017 Odyssey - ALL - ALL
http://www.urvi.net/forumfiles/SB/A16-063.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A16-063/enu/A16-063.PDF
TSB 16-108 - Safety Recall: 2011-16 Odyssey Second Row (Both Outer) Seats
Applies To: 2011-16 Odyssey - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A16-108.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A16-108/enu/A16-108.PDF
TSB 17-031 - Second-Row Center Seat Cup Holder Is Loose or Broken
Applies To: 2011-17 Odyssey - ALL - ALL
http://www.urvi.net/forumfiles/SB/A17-031.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A17-031/enu/A17-031.PDF
TSB 17-052 - 2012-13 Odyssey: Judder from the Torque Converter Lock-Up Clutch (Snapshot Required)
Applies To: 2012 Odyssey - Touring, Touring Elite - From VIN 5FNRL5H...CB054365 thru 5FNRL5H...CB148157
2013 Odyssey - Touring, Touring Elite - ALL
http://www.urvi.net/forumfiles/SB/A17-052.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A17-052/enu/A17-052.PDF
TSB 17-097 - Safety Recall: Outer Second Row Seats Tip During Braking
This bulletin is replaced by S/B 18-021, Safety Recall: Second Row Outer Seat Striker Bracket (Seat Tipping)
http://www.urvi.net/forumfiles/SB/A17-097.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A17-097/enu/A17-097.PDF
TSB 18-017 - 2012-13 Odyssey: Judder from the Torque Converter Lock-Up Clutch After Software Update (Snapshot Required)
http://www.urvi.net/forumfiles/SB/A18-017.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A18-017/enu/A18-017.PDF
TSB 18-021 - Safety Recall: Second Row Outer Seat Striker Bracket (Seat Tipping)
Applies To: 2011-17 Odyssey - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A18-021.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A18-021/enu/A18-021.PDF
TSB 19-056 - Warranty Extension: Taffeta White Paint (6 Months)
Applies To: 2011-12 Odyssey - All vehicles painted Taffeta White NH-578 - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A19-056.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-056/enu/A19-056.PDF
TSB 19-058 - Warranty Extension: White Diamond Pearl Paint (6 Months)
Applies To: 2012 Odyssey - All vehicles painted White Diamond Pearl NH-603 - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A19-058.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-058/enu/A19-058.PDF
TSB 19-111 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram
Applies To: 2005-17 Odyssey
http://www.urvi.net/forumfiles/SB/A19-111.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-111/enu/A19-111.PDF
TSB 20-023 - Front Rocker Arm Oil Control Valve Leaks
Applies To: 2008-10 Odyssey - EX-L and higher - ALL
http://www.urvi.net/forumfiles/SB/A20-023.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A20-023/enu/A20-023.PDF
I have been trying to find out if the 2012 exl or touring odyssey have changed the mounting/shaking issues due to the eco on previous year models. I am about to buy a 2008 touring but would rather buy a 2012 if they have changed it.
I have a 2012 Touring and have about 4500 miles on it. We have towed a trailer weighing about 2000lb for 500 mi. I think the vehicle drives and shifts flawlessly. I feel no vibration as the van goes in and out of ECO mode. I am an X-tech and extremely picky.
I have not experienced any issues witht eh eco shift in or out.
We've got about 400 miles on our 2012 EX....no issues. One thing I've noticed is that ECO mode kicks in and out quite often. No vibrations noticed.
2012 Polished Metal Metallic.....$32,000 with tax, title and DMV fees included out the door + $1,255 for 96 months/120k mile Honda Care warranty. Looking forward to many trouble free miles.
Super Moderator
Agreed BigBoat. Hoping they won' t me make me delete their question posts or move 'em around. :)
I'd be happy to delete my post here, but the site only provides a short period of time before it disallows changes or deletions by us mere mortals. Sorry for the improper post. Feel free to trash mine (#5)
Super Moderator
You're fine. You were just answering the nubies' questions. Lets hope more folks don't keep asking questions in this thread v/s other problem specific threads. :)
I have a 2012 EX-L and am curious to know if there is anything I should be aware of. However from work, I cannot access the two links as our administrator says that we need to be authorized to do so. This policy usually only apply to sites known to have virus, prono, etc. Can someone fix the link or just tell us what the TSB is for? Thanks.
Super Moderator
Huh?
I recommend trying from home. One link is on Honda's site and the other on my webserver. Neither are "known" virus or porno etc links. Not sure what you mean when you say fix the links. They work just fine. Too bad your work Admin won't let you access them but what needs fixing is your work's admin and not the links.
Also, what the TSB is for is already described right above the links. Thanks to EE4Life on compiling these and keeping the lists of TSBs for ALL model years up-to-date.
Just to let you know, the Honda link gives me:
You are not authorized to view the content on this page.
If you believe you have received this message in error, please contact the Support Center.
Your link opens fine.
Super Moderator
Yes. That is the whole reason there are two links. There is a work around for the Honda link that EE4Life has posted several times before. Look for his posts in the prior generation forums to make the Honda link work. Some people keep having issues with the Honda link and hence we have been hosting the PDFs on my webserver.
After finally getting the PDF file, I found that TSB11-056 is just that, PDI information. For those who are new to this, like me, PDI stands for "Pre-Delivery Inspection," a check list for the dealer to prepare the car before giving it to you. It is an interesting read, but not the kind of TSB that tells you your car has a known issue that needs to be fixed.
Super Moderator
Discussion Starter #17
Your posted TSB is for 2008 vehicles. Tell me if I'm reading it incorrectly, please!
There was an issue overwriting TSB 08-017 to dvpatel's server, but the issue is now fixed. Please check again.
I am taking delivery of a '12 Touring later this week. Should I insist that the dealer shows me proof that all applicable TSB have been applied to the vehicle? (TSB 08-017 and 11-070 are applicable to my VIN) How do dealers normally handle TSB's that affect their on-lot inventory?
TSB is not a forced recall. I think they won't do anything unless customers complain. You could mention this to see what they say. If necessary, ask the service manager to go with you on a test drive before you sign the paper. The van either has these problems or not.
Hey just a thought to the original poster.. Maybe on the TSBs put in an added date? Or date of TSB issue date before the description?
Just thought that it might help, for chronological purposes, to know what was added when or when the TSB was issued.
1 - 20 of 39 Posts
Status
