Hey all
The strut mounts and/or strut bellows/insulators are bad, creaking/making noise.
How long does the front end last on these Odysseys? Front struts, front strut bellows and insulators, front strut mounts, inner and outer tie rod ends, sway bar bushings, control arm's bushings and ball joints? Is 115k miles a normal time to have to replace some or all of these parts? I'm trying to put a parts order together, and I'm not sure how much to get.
How about how long CV axles last? There is some slight build up on the two front CV axle boots.
Also how long does the PS rack/pinion last? This one has some build up on the bottom due to a small leak. Also some build up at the pump area. Not major PS fluid loss between oil changes (7.5k miles), but definitely some loss. I do have Lucas Power steering leak additive, but I have not used it.
I am debating whether to just do "everything" at the same time, since when some parts start to go, it may not be long before more goes.
