My 2012 odyssey passenger high beam is out, and the DRL light comes on. I already replaced the bulb and swapped the relays. I cannot seem to find a bad fuse or relay.
Any ideas?
I keep hearing about the DRL relay, but that issue seems to be with previous generation odysseys.
Maybe a bad ground?
Any help appreciated, trying to avoid trip to dealership.
start here...
Thank you!
start here...
Discussion Starter #4
Thank you for the help, I check the relays, fuses, bubls, but could not find the issue. I finally took it to the dealer, they found a break in the wiring harness. $300 but at least it is fixed.
