Hello guys, my back up camera on 2015 Honda Odyssey has turned dark suddenly. I can sometimes see slight shadows but mostly dark. I can see the lines but screen is basically black. Yes, I have tried adjusting the brightness, it doesn't work. Here is a link to my YouTube video describing the problem. Blind spot camera works, just backup doesn't. Any suggestions on what can be done?
initial cost free option...
start off by checking the connection to the camera for any corrosion, maybe spray some cleaner into the connector.
you should be able to access the connector without removing the entire rear panel.
The HDS and foxwell can perform tests on the rear camera, if you dont have one then pay for the diagnostics.
multiple options for a replacement, standard auto wreckers or dealer.
