Status
Not open for further replies.
Technische Service-Bulletins für den Honda Odyssey 2015
51K views 1 reply 1 participant last post by  EE4Life
#1 · (Edited)
Here is what is required to be able to access the Honda/Acura links:
1. Open this Honda eStore link: HONDA Odyssey Accessories – Installation Instructions Download – presented by HONDA eStore
2. Open any Honda/Acura link
Note: The Honda eStore link allows access to the Honda/Acura links for ~ 1 day, otherwise you will then get an error message. If you get an error message, just follow the steps again to regain access.
TSB 14-043 - 2015 Odyssey: PDI Information
Applies To: 2015 Odyssey - LX, EX, EX-L, EX-L with RES, EX-L with Navigation, Touring, Touring Elite
http://www.urvi.net/forumfiles/SB/A14-043.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A14-043/enu/A14-043.PDF
TSB 14-044 - 2015 Odyssey: PDI of the Navigation System
Applies To: 2015 Odyssey - All with Navigation
http://www.urvi.net/forumfiles/SB/A14-044.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A14-044/enu/A14-044.PDF
TSB 14-022 - Function Buttons (PHONE, MENU, BACK, SETTINGS, Etc.) Stick
Applies To: 2014 Odyssey - ALL - ALL
2015 Odyssey - EX, EX-L, Touring - From VIN 5FNRL5...FB000001 thru 5FNRL5...FB115934
http://www.urvi.net/forumfiles/SB/A14-022.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A14-022/enu/A14-022.PDF
TSB 14-038 - Front Brake Caliper Bracket Contacts Rotor Causing Grinding, Rubbing, or Screeching Noise
Applies To: 2014 Odyssey - ALL - From VIN 5FNRL5...EB098185 thru 5FNRL5...EB110523
2015 Odyssey - ALL - From VIN 5FNRL5...FB009095 thru 5FNRL5...FB014769
http://www.urvi.net/forumfiles/SB/A14-038.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A14-038/enu/A14-038.PDF
TSB 14-073 - New Warranty Instructions for TPMS-Related Repairs
Applies To: 2007-15 Odyssey - ALL
http://www.urvi.net/forumfiles/SB/A14-073.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A14-073/enu/A14-073.PDF
TSB 14-074 - Third Row Seat Cup Holder Gets Warm
Applies To: 2011-15 Odyssey - ALL
http://www.urvi.net/forumfiles/SB/A14-074.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A14-074/enu/A14-074.PDF
TSB 14-076 - Rattle From the Tailgate Area On Rough Roads or Going Over Bumps
Applies To: 2011-15 Odyssey - All with power tailgate - ALL
http://www.urvi.net/forumfiles/SB/A14-076.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A14-076/enu/A14-076.PDF
TSB 15-002 - Vehicles with Navigation: Audio Turns Off After Using HFL, No Sound/Static in Rear Headphones, and Other Listed Issues
Replaces S/B 14-019, Product Update: Audio-Navigation Unit Software Update
Applies To: 2014 Odyssey - EX-L with navigation - ALL
2014 Odyssey - Touring with navigation - ALL
2015 Odyssey - EX-L with navigation - ALL
2015 Odyssey - Touring with navigation - ALL
http://www.urvi.net/forumfiles/SB/A15-002.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A15-002/enu/A15-002.PDF
TSB 15-014 - Hard Downshift or Clunk When Slowing Down to a Rolling Stop
2015 Odyssey - ALL - From VIN 5FNRL5...FB000001 thru 5FNRL5...FB070938
http://www.urvi.net/forumfiles/SB/A15-014.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A15-014/enu/A15-014.PDF
TSB 15-032 - Roof Rack Rattles
Applies To: 2011–15 Odyssey - ALL
http://www.urvi.net/forumfiles/SB/A15-032.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A15-032/enu/A15-032.PDF
TSB 15-064 - Door Sash Outer Trim Is Warped
http://www.urvi.net/forumfiles/SB/A15-064.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A15-064/enu/A15-064.PDF
TSB 16-004 - Product Update: 2015 Odyssey Vehicle Certification Label
Applies To: 2015 Odyssey - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A16-004.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A16-004/enu/A16-004.PDF
TSB 16-005 - Multiple Indicators Are On With DTC 81-1 and/or DTC 61-1
Applies To: 2011-14 Odyssey - ALL - ALL
2015 Odyssey - ALL - From VIN 5FNRL5...FB000001 thru 5FNRL5...FB039984
http://www.urvi.net/forumfiles/SB/A16-005.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A16-005/enu/A16-005.PDF
TSB 16-024 - Popping or Clicking When Turning the Steering Wheel
Applies To: 2015-16 Odyssey - ALL - ALL
http://www.urvi.net/forumfiles/SB/A16-024.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A16-024/enu/A16-024.PDF
TSB 16-035 - Creak From the B-pillar
Applies To: 2014-15 Odyssey - ALL - ALL
2016 Odyssey - ALL - From VIN 5FNRL....GB000001 thru 5FNRL....GB044289
http://www.urvi.net/forumfiles/SB/A16-035.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A16-035/enu/A16-035.PDF
TSB 16-050 - Squeak From the Front Suspension
http://www.urvi.net/forumfiles/SB/A16-050.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A16-050/enu/A16-050.PDF
TSB 16-051 - Safety Recall: 2015–16 Odyssey and 2016 Pilot Fuel Tank
Applies To: 2015-16 Odyssey - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A16-051.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A16-051/enu/A16-051.PDF
TSB 16-060 - Judder from the Torque Converter Lock-Up Clutch
This bulletin is replaced by 17-052, 2012-13 Odyssey: Judder from the Torque Converter Lock-Up Clutch (Snapshot Required), and 18-017, 2012-13 Odyssey: Judder from the Torque Converter Lock-Up Clutch After Software Update (Snapshot Required)
http://www.urvi.net/forumfiles/SB/A16-060.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A16-060/enu/A16-060.PDF
TSB 16-063 - Tailgate Will Not Open from the Outside Handle in Cold Weather
Applies To: 2011-2017 Odyssey - ALL - ALL
http://www.urvi.net/forumfiles/SB/A16-063.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A16-063/enu/A16-063.PDF
TSB 16-108 - Safety Recall: 2011-16 Odyssey Second Row (Both Outer) Seats
Applies To: 2011-16 Odyssey - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A16-108.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A16-108/enu/A16-108.PDF
TSB 17-031 - Second-Row Center Seat Cup Holder Is Loose or Broken
Applies To: 2011-17 Odyssey - ALL - ALL
http://www.urvi.net/forumfiles/SB/A17-031.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A17-031/enu/A17-031.PDF
TSB 17-043 - 2014–17 Odyssey: Judder from the Torque Converter Lock-Up Clutch (Snapshot Upload Required)
Applies To: 2014–17 Odyssey - ALL - ALL
http://www.urvi.net/forumfiles/SB/A17-043.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A17-043/enu/A17-043.PDF
TSB 17-044 - 2014–17 Odyssey: Judder from the Torque Converter Lock-Up Clutch After Software Update (Snapshot Upload Required)
http://www.urvi.net/forumfiles/SB/A17-044.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A17-044/enu/A17-044.PDF
TSB 17-097 - Safety Recall: Outer Second Row Seats Tip During Braking
This bulletin is replaced by S/B 18-021, Safety Recall: Second Row Outer Seat Striker Bracket (Seat Tipping)
http://www.urvi.net/forumfiles/SB/A17-097.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A17-097/enu/A17-097.PDF
TSB 18-021 - Safety Recall: Second Row Outer Seat Striker Bracket (Seat Tipping)
Applies To: 2011-17 Odyssey - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A18-021.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A18-021/enu/A18-021.PDF
TSB 18-026 - Safety Recall: Left (Driver Side) Second Row Seat Recliner Does Not Lock
Applies To: 2014-16 Odyssey - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A18-026.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A18-026/enu/A18-026.PDF
TSB 19-111 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram
Applies To: 2005-17 Odyssey
http://www.urvi.net/forumfiles/SB/A19-111.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-111/enu/A19-111.PDF
TSB 20-023 - Front Rocker Arm Oil Control Valve Leaks
Applies To: 2008-10 Odyssey - EX-L and higher - ALL
http://www.urvi.net/forumfiles/SB/A20-023.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A20-023/enu/A20-023.PDF
TSB 23-103 - Safety Recall: Multi-Model Honda Fuel Pump Motor Stop Sale
Applies To: 2014-17 Odyssey - ALL - Check the iN VIN status for eligibility
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A23-103/enu/A23-103.PDF
TSB 24-076 - Safety Recall: 2013–17 Odyssey Fuel Pump Module Set/Assembly Replacement
Applies To: 2013-17 Odyssey - ALL - Check the iN VIN status for eligibility
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A24-076/enu/A24-076.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A24-076/enu/A24-076 v3.PDF (Link works, but is wrong) Version 3
TSB 25-061 - Warranty Extension: 2013–17 Odyssey MIL Comes on with DTCs P0301 Thru P0304 (6 months)
Save
Neue TSB 25-061 hinzugefügt - Garantieverlängerung: 2013–17 Odyssey MIL leuchtet mit DTCs P0301 bis P0304 (6 Monate).
Save
Status
You have insufficient privileges to reply here.
