1 - 20 of 22 Posts
I bought a power inverter at Walmart to plug into the 12v power outlets in my 2016 Honda Odyssey to allow us to charge a laptop. When I plugged it into the power outlets, the "power on" LED for the power inverter wouldn't even come on. I am hearing that the Odyssey 12v outlets won't support plug-in power inverters for this purpose. Any suggestions? Is there an inverter I can buy that will work?
Obvious first question:
Did you try a different inverter and/or did you try the inverter in a different vehicle? That's a sure way to narrow it down to the inverter vs. the ody.
I run a cheap HF inverter in my 06 so I can use the fast charger for my phone. I have also charged my iPad and Chromebook at the same time that I'm charging my phone. I guess it's possible that they "down-spec'ed" the power outlets in the 16 vs. the 06, but I'd be surprised if that were the case.
Where have you been hearing that the Ody won't support plug-in inverters?
Yes - I tried 2 different inverters - both didn't work in the 2016 Odyssey and both worked in my 2016 Accord.
The dealership said the outlets won't support some inverters that pull over a certain wattage/voltage/amperage, but would not give me an guidance on how to know which ones would work and which wouldn't. Based on what they said both inverters should work but neither do.
I run an extension cord from the rear outlet on my '12, it has charged my wife's laptop just fine for years now.
What did they say? (You aren't supplying a lot of detail, so it's hard for us to give you a good answer)
What size inverter are you trying to use? Aren't the power outlets spec'd for 10A @ 12V? I'm pretty that means that the inverter itself must be using more than 120 watts if it can't even power up. That seems strange.
You may need to spring for an inverter that runs directly off of the battery. Something like this. (Just an example, I'm not endorsing HF inverters)
Or carry one of these around, but keep the windows open. 😀
Do the outlets work for normal cell phone chargers, etc? Any chance the fuses are just blown?
-Charlie
What is the model of the inverter?
What laptop are you trying to charge?
As someone else asked - does the outlet power anything like a cellphone charger - does the inverter have a LED that lights up indicating power / works in another outlet?
If you are trying to charge a Macbook with USB C they require a decent amount of wattage (but nothing your setup shouldnt be able to handle.) I use this for macbooks / nintendo switch and it has worked pretty reliably: womp womp cant post links because im new. (Maxboost USB C quick charge on amazon)
If you let us know more info we could probably point you to a solution.
Just noticed your follow up where you say your setup works in your accord - chances are it is a combination of insufficient wire gauge in combination with the distance from the battery. Could be a pain but upgrading the wire from the fuse box back to the outlet would be helpful - but at that point it is almost worth it to just hard wire a inverter then. Would just have to use a thicker gauge than stock.
Discussion Starter #9
Inverter is "Powerline" 90359. I have another one that also didn't work in the van - not sure where that one is now.
Never go to charging the laptop because the inverter would never power up - but one is a typical Dell and the other is an Apple.
Yes the outlet works for an adapter powering a USB for phones.
Yes the LED lit up when I plugged it into my Accord. Didn't light when plugged into either power outlet for the Odyssey.
That inverter has a voltage detection feature. If the vehicle outlet voltage is high or low, the unit will not go into a ready state.
Clean the positive (center) outlet connector with a pencil-tipped eraser. It may have accumulated some corrosion or other resistance that is sapping some voltage.
Dave
Discussion Starter #11
Dave
It is new right out of the package
Actually, I meant cleaning the power outlet contact, as opposed to the inverter contact.
Dave
Why don't you plug in a power cord in the rear plug in and skip the inverter? Works great on my wife's laptop and cell phone charger
I've run a 400W inverter in mine with no issues - wasn't drawing that much, just charging a laptop, but it worked fine.
Yeah, a laptop charger draws at most about 100 watts so the stock power outlet will handle it no problem.
The inverter max power rating is its upper limit, but its power draw is determined by whatever is plugged into it.
Dave
1 - 20 of 22 Posts
