Status
Not open for further replies.
Super Moderator
Here is what is required to be able to access the Honda/Acura links:
1. Open this Honda eStore link: HONDA Odyssey Accessories – Installation Instructions Download – presented by HONDA eStore
2. Open any Honda/Acura link
Note: The Honda eStore link allows access to the Honda/Acura links for ~ 1 day, otherwise you will then get an error message. If you get an error message, just follow the steps again to regain access.
TSB 17-029 - 2018 Odyssey: PDI and New Model Service Information
Applies To: 2018 Odyssey - LX, EX, EX-L, EX-L with Navigation and Rear Entertainment System, Touring, Elite
http://www.urvi.net/forumfiles/SB/A17-029.PDF
LinkDeny
TSB 17-030 - 2018 Odyssey: PDI of the Navigation System
Applies To: 2018 Odyssey - All with Navigation
http://www.urvi.net/forumfiles/SB/A17-030.PDF
LinkDeny
TSB 16-013 - High Pressure Fuel Pump Chirps
Applies To: 2018-19 Odyssey - ALL - ALL
http://www.urvi.net/forumfiles/SB/A16-013.PDF
LinkDeny
TSB 16-087 - Transmission End Cover Leaks (9-Speed A/T)
Applies To: 2018 Odyssey - LX, EX, EX-L - ALL
2019 Odyssey - LX, EX, EX-L - From VIN 5FNRL6H..KB000031 thru 5FNRL6H..KB021038
http://www.urvi.net/forumfiles/SB/A16-087.PDF
LinkDeny
TSB 17-036 - MIL Comes On with DTC P0430 (Front Bank Catalyst System Efficiency Below Threshold [Bank 2])
This bulletin is replaced by S/B 19-072, MIL Comes On with DTC P0430 (Front Bank Catalyst System Efficiency Below Threshold [Bank 2]) (With Software Update)
http://www.urvi.net/forumfiles/SB/A17-036.PDF
LinkDeny
TSB 17-055 - Non-Compliance Recall: 2018 Odyssey 3rd Row Center Seatbelt Tongue
Applies To: 2018 Odyssey - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A17-055.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A17-055/enu/A17-055.PDF
TSB 17-075 - Service Manual Update: Sliding Door Position Adjustment
http://www.urvi.net/forumfiles/SB/A17-075.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A17-075/enu/A17-075.PDF
TSB 17-088 - Check Tuner and/or Radio Unavailable Message on the Audio Unit/ Audio-Navigation Unit
Applies To: 2018 Odyssey - EX - From VIN 5FNRL6H...JB000002 thru 5FNRL6H...JB021567
2018 Odyssey - EX-L with Navigation/RES - From VIN 5FNRL6H...JB000003 thru 5FNRL6H...JB021781
2018 Odyssey - EX-L - From VIN 5FNRL6H...JB000022 thru 5FNRL6H...JB021624
2018 Odyssey - Touring - From VIN 5FNRL6H...JB000009 thru 5FNRL6H...JB021682
2018 Odyssey - Elite - From VIN 5FNRL6H...JB000001 thru 5FNRL6H...JB021741
http://www.urvi.net/forumfiles/SB/A17-088.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A17-088/enu/A17-088.PDF
TSB 17-090 - Product Update: 2018 Odyssey Rear Power Window Switches
Applies To: 2018 Odyssey - ALL except LX - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A17-090.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A17-090/enu/A17-090.PDF
TSB 18-007 - Product Update: 2018 Odyssey Honda Dealer Wi-Fi Connection Failure and Navigation Update
Applies To: 2018 Odyssey - EX-L RES/Navi, Touring, Elite - Check the iN VIN status eligibility
http://www.urvi.net/forumfiles/SB/A18-007.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A18-007/enu/A18-007.PDF
TSB 18-008 - Product Update: 2018 Odyssey Navigation Software Update
Applies To: 2018 Odyssey - EX-L with RES/Navi, Touring, Elite - Check the iN VIN status eligibility
http://www.urvi.net/forumfiles/SB/A18-008.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A18-008/enu/A18-008.PDF
TSB 18-009 - Product Update: 2018 Odyssey Honda Dealer Wi-Fi Connection Failure
Applies To: 2018 Odyssey - EX, EX-L - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A18-009.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A18-009/enu/A18-009.PDF
TSB 18-018 - Capless Shutter Set (Mis-Fuel Inhibit Device) Is Frozen
Applies To: 2018 Odyssey - ALL - ALL
http://www.urvi.net/forumfiles/SB/A18-018.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A18-018/enu/A18-018.PDF
TSB 18-025 - MIL Comes On with DTC P0300-P0306 or P219A/B
2019 Odyssey - ALL - From VIN 5FNRL6...KB000001 thru 5FNRL6...KB026674
http://www.urvi.net/forumfiles/SB/A18-025.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A18-025/enu/A18-025.PDF
TSB 18-086 - Service Manual Update: F-CAN Bus Connected Unit Check
http://www.urvi.net/forumfiles/SB/A18-086.PDF
http://techinfo.honda.com/Rjanisis/pubs/SB/AH/A18-086/enu/A18-086.PDF
TSB 18-121 - 2018 Odyssey: Bluetooth HandsFreeLink Will Freeze After Calls and Voice Tags Are Missing at Startup
Applies To: 2018 Odyssey - LX - ALL
http://www.urvi.net/forumfiles/SB/A18-121.PDF
http://techinfo.honda.com/Rjanisis/pubs/SB/AH/A18-121/enu/A18-121.PDF
TSB 18-125 - Noise from the Front Driver Door Speaker at 1500 RPM
Applies To: 2018 Odyssey - Elite - ALL
2019 Odyssey - Elite - From VIN 5FNRL6...KB000001 thru 5FNRL6...KB056230
http://www.urvi.net/forumfiles/SB/A18-125.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A18-125/enu/A18-125.PDF
TSB 18-128 - Safety Recall: Power Sliding Door Rear Latches
Applies To: 2018-19 Odyssey - ALL except LX - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A18-128.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A18-128/enu/A18-128.PDF
TSB 18-129 - Safety Recall: Soft or Low Brake Pedal
Applies To: 2018-19 Odyssey - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A18-129.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A18-129/enu/A18-129.PDF
TSB 19-022 - Rear Climate Control Panel Buttons Do Not Work
http://www.urvi.net/forumfiles/SB/A19-022.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-022/enu/A19-022.PDF
TSB 19-023 - High-Pitched Noise from the Heater Case
Heater Case Mis-alignment
Applies To: 2018 Odyssey - ALL - From VIN 5FNRL6H...JB000001 thru 5FNRLH...JB047001
Blower Motor Only
2019 Odyssey - ALL - From VIN 5FNRL6H..KB000001 thru 5FNRL6H..KB023543
http://www.urvi.net/forumfiles/SB/A19-023.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-023/enu/A19-023.PDF
TSB 19-028 - Power Sliding Door Reverses Direction When Closing
Applies To: 2018 Odyssey - ALL except LX - ALL
2019 Odyssey - ALL except LX - From VIN 5FNRL6H..KB000001 thru 5FNRL6H..KB022148
http://www.urvi.net/forumfiles/SB/A19-028.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-028/enu/A19-028.PDF
TSB 19-043 - Safety Recall: 2018-19 Odyssey Battery Terminal Inspection and Transmission Replacement
Applies To: 2018-19 Odyssey - Touring, Touring-Elite - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A19-043.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-043/enu/A19-043.PDF
TSB 19-046 - Safety Recall: 2018-19 Odyssey Check Park Mechanism (Snapshot
Upload Required), Battery Terminal Inspection, and Update TCM
Applies To: 2018-19 Odyssey - Touring, Elite - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A19-046.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-046/enu/A19-046.PDF
TSB 19-071 - Auto Idle Stop Does Not Work (BMS Inhibited)
Applies To: 2018-19 Odyssey - Elite, Touring - ALL
http://www.urvi.net/forumfiles/SB/A19-071.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-071/enu/A19-071.PDF
TSB 19-072 - MIL Comes On with DTC P0430 or DTC P0430 with P030X, P219A, P219B (With Software Update)
This bulletin replaces A17-036, MIL Comes On with DTC P0430 (Front Bank Catalyst System Efficiency Below Threshold [Bank 2])
Applies To: 2018 Odyssey - ALL - From VIN 5FNRL6...JB000001 thru 5FNRL6...JB014844
http://www.urvi.net/forumfiles/SB/A19-072.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-072/enu/A19072.PDF (Link works, but last portion is wrong)
TSB 19-073 - MIL Comes On with DTC P0430 or DTC P0430 with P030X, P219A or P219B (Without Software Update)
Applies To: 2018 Odyssey - ALL - VINs starting from 5FNRL6...JB014845
http://www.urvi.net/forumfiles/SB/A19-073.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-073/enu/A19-073.PDF
TSB 19-096 - Product Update: Display Audio Clock Off by 1 Hour
Applies To: 2018-20 Odyssey - ALL Except LX - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A19-096.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-096/enu/A19-096.PDF
TSB 19-097 - Service Manual Update: MOST Bus Network Failure Log
Applies To: 2018-20 Odyssey - ALL except LX - ALL
http://www.urvi.net/forumfiles/SB/A19-097.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-097/enu/A19-097.PDF
TSB 19-124 - 9-Speed A/T Hard Upshift with Steady Acceleration or MIL On with DTC P0716
Applies To: 2018-19 Odyssey - LX, EX, EX-L with 9-speed A/T - ALL
http://www.urvi.net/forumfiles/SB/A19-124.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-124/enu/A19-124.PDF
TSB 20-012 - Safety Recall: Third Row Accessory Power Outlet
Applies To: 2018-20 Odyssey - EX-L, EX-L with Navigation and RES, Touring, and Elite - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A20-012.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A20-012/enu/A20-012.PDF
TSB 20-013 - RES Is Frozen with Cabin Watch Error Message
Applies To: 2018 Odyssey - EX-L with RES - ALL
2018 Odyssey - Touring, Elite - ALL
2019 Odyssey - EX-L with RES - From VIN 5FNRL6H...KB000001 thru 5FNRL6H...KB021692
2019 Odyssey - Touring, Elite - From VIN 5FNRL6H...KB000001 thru 5FNRL6H...KB021738
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A20-013/enu/A20-013.PDF
Super Moderator
Discussion Starter #2
Added new TSB 20-012 - Safety Recall: Third Row Accessory Power Outlet.
Super Moderator
Added new TSB 20-013 - RES Is Frozen with Cabin Watch Error Message.
Status
